Author Topic: Multiple boats on 1 transmitter?  (Read 5466 times)
bikerdude666
« on: July 30, 2011, 10:55:07 am »
Just wondering, I know you can have a transmitter and multiple receivers in different boats, but is it possible to run 2 of the boats off the same transmitter at the same time?
Am thinking a 4 channel transmitter using 1 stick for each boat.
Arrow5
Re: Multiple boats on 1 transmitter?
« Reply #1 on: July 30, 2011, 10:57:47 am »
Yes, only thing is you need two brains too. :}
..well can you land on this?
Nige52
« Reply #2 on: July 30, 2011, 10:58:44 am »
19 of my boats run off one single transmitter, an Esky 2.4ghz, my 7 yachts all run off a single Planet 5 transmitter, all have their own receivers. I doubt very much you could run 2 boats at the same time off one transmitter, but never having risked it, I don't know.....
wibplus
« Reply #3 on: July 30, 2011, 11:01:39 am »
It can be done with Xtal sets but not with 2.4gHz sets. 2.4gHz locks on to one frequency and locks out all others.
dodgy geezer
« Reply #4 on: July 30, 2011, 11:35:03 am »
You could manage it in one body if you had a full frontal lobotomy....  %% Just remember that the left brain hemisphere operates the right side of your body, and vice versa...
If you bind two receivers to the same transmitter they should both accept and action the same signals. Then it's just a matter of plugging servos into channels 1 and 2 on the first receiver, and 3 and 4 on the second. Of course, if you want to do ever-so-precise formation work, you could plug them into the same channels, and hope that ALL other influences are PRECISELY identical..... :D :D
CF-FZG
« Reply #5 on: July 30, 2011, 11:50:12 am »
That's really a bad statement to make - as it's patently incorrect :police:
2.4 has upto 80 frequencies available, and depending on the system, uses either ;
all of them - and moves between them all - Foobar, Jeti, MPX, the new JR system, and some others
half of them - and moves between them all - Spektrum DSMX
2 of them - and hops between the 2 'channels' - JR DSM2 and Spektrum DSM2
or 1 of them - the one you're thinking of, which just sticks to that 1 channel - early XPS and some of the cheap 'toy' sets.
The 'single channel' sets are restricted to 10mW ERP output, whereas the others are allowed 100mW ERP output
To answer the OP, YES it can be done, quite easily, as wibplus says - by binding both Rx at the same time and using the relevant Rx connectors to match the two 'models' set up on the Tx :-))
Mark
cos918
« Reply #6 on: July 30, 2011, 12:42:28 pm »
I Have done it
To make it work is not hard and I did it on 2.4ghz.
The big problem is trying to keep control of both boats. If they are running parrell in the samme direction and the same speed running the same course \ partten then it is not to hard have one coming at you and the other going away or at 90 deg it comes very intense on the brain put speed in to the equation then all hell breaks lose and you are all ways having to corect course and speed
john
kinmel
« Reply #7 on: July 30, 2011, 03:37:08 pm »
No problem on 2.4
Boat 1 uses the left hand stick, boat 2 uses the right hand stick  - ie 2 by 2 channel systems on a 4 channel transmitter.
You need to be good though to make the correct inputs to each stick when the boats are moving independently.
bikerdude666
« Reply #8 on: July 31, 2011, 12:08:45 am »
Thanks for the replies, I've currently got the giant cod 'tight a$$' transmitter and receiver, would you think it would work ok with that or do I need to get a better set.
Controlling 2 shouldn't be too hard, won't be trying to do 2 different things at once in different parts of the lake. Want to shadow my 1/72 flower class corvette with a 1/72 u-boat so they'd both be doing the same circuit, so hopefully wouldn't be too challenging (he says as he rams his own corvette sinking both models! Lol)
« Reply #9 on: July 31, 2011, 07:55:38 am »
Hope you're surface running the uboat 2.4GHz is a no no underwater
kinmel
« Reply #10 on: July 31, 2011, 08:06:21 am »
 "the giant cod 'tight a$$' transmitter and receiver" works perfectly with multiple receivers.
« Reply #11 on: July 31, 2011, 03:54:07 pm »
I tried this today with two Springers.  There is a report under that title in the Springer section.
Great fun as  Coz918  says. It's rather like rubbing your Tummy and patting your Head at the same time.   :} :}  beware of driving towards each other.   {-)
Just one comment about the Planet T5 regarding channels.  One stick controls channels 1 & 3  and the other stick controls channels 2 & 4.
Ken
Nordsee
« Reply #12 on: July 31, 2011, 05:04:43 pm »
Bind 2 Rxs to one Tx, then use left hand stick for one boat, R.hand for another?
colin-d
« Reply #13 on: July 31, 2011, 05:33:19 pm »
i use the corona 2,4Ghz DIY sets.... one (1) transmiter and two (2) receivers in diverent boats.... No problem what so ever...
same on the 40Mhz... 1 Transmiter and god knows how many receivers all on the same channel...
i used to sail my Norderney and Mowe in this way, left stick main Ship and the right stick the ships boat..
nemesis
« Reply #14 on: July 31, 2011, 05:37:59 pm »
Hello, This topic has been on before, One of our members did this years ago with two flower class corvettes. It was fun when they were coming at you,  Nemesis
Subculture
    • Dive-in to Model submarines
« Reply #15 on: July 31, 2011, 06:04:48 pm »
We used to have a chap at Broomfield called Dennis Reubens who operated two models at once  with his Fleet R/C.
Page created in 0.579 seconds with 18 queries.
