Pages: 1 2 3 4 5 6 7 8 [9] 10 11 12   Go Down
Author Topic: My Build of H.M.T. RESOLVE from June 2011  (Read 108083 times)
wallace
Re: My Build of H.M.T. RESOLVE from June 2011
« Reply #200 on: March 11, 2013, 12:22:05 pm »
Heres more photos of the build of the Anchor Windless all parts were cleaned and rub down all had 2 coats of primmer and 3 coats of top coat (black gloss) just the hand wheels to paint there is a few moving parts but all will be ok when the chain is put on.
                     wallace  :-)) :-)) :-))
wallace
« Reply #201 on: March 11, 2013, 12:25:10 pm »
some more of the Windless.
                   wallace  :-)) :-))
wallace
« Reply #202 on: March 19, 2013, 10:54:25 am »
A few more of  the stern winch.
    wallace  :-)) :-))
wallace
« Reply #203 on: March 21, 2013, 04:55:31 pm »
Putting the towing gear together and painting.
   wallace  :-)) :-))
« Reply #204 on: March 21, 2013, 05:00:15 pm »
Good going Wallace the towing winches and gear are
models in there own right
They really look great
wallace
« Reply #205 on: March 22, 2013, 09:59:49 am »
More on the towing gear and the aft winch all had two coats of black gloss.
Please note as always with my building I have not fully fixed in place only put on so I can see if Im happy with them just a little bit of painting to do on the hand wheels.
   wallace  :-)) :-))
Many thanks ned for your kind words they all make me happy during the build  :-) :-)
« Reply #206 on: March 22, 2013, 08:42:54 pm »
Lovely winches and nice photos Wallace  O0
wallace
« Reply #207 on: March 23, 2013, 11:30:45 am »
A few more of the towing gear , the towing gear is built around the aft mast and on each side are 2 med vents the mast is nearly all done and the vents are put together and given two coats of primer the photos shows all in place but they are not fixed as of yet just want to see if all looks ok the mast will not be fixed until I work out how to do the lighting Im no good at it my last boat a friend done it for me but i dont like always asking to get things done  I will get there there.I hope anyway thats you like the build.
Thanks alot to the lovely replies of the build.
                wallace  :-)) :-))
wallace
« Reply #208 on: March 25, 2013, 11:48:41 am »
I'm back to the flying bridge, as the photos show had to drill 13  .07mm holes for the stanchions these are for the awning stanchions,if I had done them before I fitted the wood cladding around the bridge I think the holes would have been all wrong so I'm glad I have done them this way.As the photo shows the under side of the bridge deck has not been treated with anything which made things alot better to mark out,I took my time and measued and checked many times before I drill the holes have tested the holes with the wire and all looks good,also to put into place the support strut spacer bars which will come to light later.A lot of things and work to be done  but I will post things as I go along.
                    wallace  :-)) :-))
wallace
« Reply #209 on: March 29, 2013, 04:48:48 pm »
And more hoping you can follow the build ok I have changed bits on the awning beams and stanchions have used 1.2mm brass rod for the stanchions and 3mm x 2mm for the beams  reason being it makes it alot stronger stops little hands from breaking it all looks a bit messie at the moment but it will be ok when finnished.
wallace
« Reply #210 on: March 29, 2013, 05:33:43 pm »
Re run of photos
         wallace :-)) :-)) :-)) :-))
wallace
« Reply #211 on: March 29, 2013, 05:35:46 pm »
and more of the re-run
   wallace  :-)) :-) :-) :-)
wallace
« Reply #212 on: March 29, 2013, 06:33:44 pm »
Still on the flying bridge  well the frame is almost done  will be leaving it to rest for 24 hours then I may do some filling at the joins then it will all be painted as you can see its a real mess at the moment been rubbing it down a wee bit when all done all the varnish is going to be re done,so the photos show what I have done in the build from all angles looking at it I'm happy at the moment.
wallace
« Reply #213 on: March 29, 2013, 06:36:20 pm »
more of the build.
wallace
« Reply #214 on: April 02, 2013, 10:26:23 am »
more on the flying bridge been prime and just looking to see what it looks like before top coat goes    not to happy with it going to re sand etc then paint again,also a photo of the small vent that sits next to the towing gear.
     wallace  :-)) :-))
wallace
« Reply #215 on: April 03, 2013, 11:49:27 am »
Photos of the flying bridge re-done  what i done was sanded all the wood and while I was doing it a beam just came away had to clean it up and when put back together it was to small would not fit into the holes in the deck so I made a new one and it fits this time ,at the moment it looks ok will give it a all over top coat but cannot fit into place as the bridge needs all re varnishing etc.also bits to add to the deck.
            wallace  :-)) :-))
eddiesolo
« Reply #216 on: April 03, 2013, 12:17:40 pm »
Looking awesome, love the piccies. Looks a cracking model and superb build sir!  :-))
Si:)
wallace
« Reply #217 on: April 06, 2013, 10:56:46 am »
More on the flying bridge have painted the awning beams and stanchions top coat navy grey and the stanchions i went with a darker grey also the photos show some of the fittings that go on the bridge they are just held in place with blue tack just a little bit of painting on the fitting and when i have re done the deck all will be fitted.
                      wallace  :-)) :-))
wallace
« Reply #218 on: April 14, 2013, 12:47:54 pm »
A few more of the bridge  all coming together now in the photos only half are fixed into place  looking good.
                 wallace  :-)) :-))
wallace
« Reply #219 on: April 21, 2013, 11:31:30 am »
more on the build
    wallace  :-)) :-))
wallace
« Reply #220 on: April 21, 2013, 11:34:24 am »
and more these are the bits to go on the boat/funnel deck.
            wallace  :-)) :-))
wallace
« Reply #221 on: April 22, 2013, 11:53:58 am »
more of the boat deck
               wallace  :-)) :-))
wallace
« Reply #222 on: April 24, 2013, 10:40:04 am »
What is up with this site just cant get anything on getting told after 5 mins the site is busy.
             wallace
wallace
« Reply #223 on: April 24, 2013, 10:42:06 am »
trying again
wallace
wallace
« Reply #224 on: April 27, 2013, 12:18:25 pm »
more
Pages: 1 2 3 4 5 6 7 8 [9] 10 11 12   Go Up
Page created in 0.02 seconds with 18 queries.
