Author Topic: release valve  (Read 3609 times)
Andy_k
release valve
« on: September 01, 2011, 06:09:58 pm »
Hi can anybody tell me what is generally used to hold or release the water in a sealed ballast tank system ? as I know the pressure will push back past the pump.
Is it something I can make or is it a bought item ?
Right which one will I do next?;)
andyn
Re: release valve
« Reply #1 on: September 01, 2011, 06:21:34 pm »
I've used pinch valves, basically a servo pushes a steel rod into a block with the silicon tube from the pump through it.
You can either message Sheerline for one, or I'll make you one.
Andy :-)
thegrimreaper
Re: release valve
« Reply #2 on: September 01, 2011, 06:26:04 pm »
try this link theire is a picture of what you need to make half way down the topic
http://www.modelboatmayhem.co.uk/forum/index.php?topic=28915.0
Regards Mark
thegrimreaper
Re: release valve
« Reply #3 on: September 01, 2011, 06:28:09 pm »
sorry the valve is on the left with the tubing going through it and an offset cam on a servo to open and close the valve plus strat the pump via the micro switch
Andy_k
Re: release valve
« Reply #4 on: September 01, 2011, 08:15:42 pm »
OK that seem straight forward Andy I am going to have a go at making one but may come back to you if thats OK
Mark do you use a standard servo on that or heavy duty ?
Andy
thegrimreaper
Re: release valve
« Reply #5 on: September 02, 2011, 08:32:05 am »
@ Andy_k
Chris from Sheerline recommends a ball raced servo which is what I use think it cost me about a fiver never had a problem with the system used Andy
Regards Mark
andyn
Re: release valve
« Reply #6 on: September 02, 2011, 03:31:13 pm »
Futaba S3004 or S148 will do the job perfectly :-)
Davy1
Re: release valve
« Reply #7 on: September 03, 2011, 09:07:03 am »
You may find this discussion thread useful (Several different methods + design principles reviewed:
http://www.theassociationofmodelsubmariners.com/t380-pinch-valves
Andy_k
Re: release valve
« Reply #8 on: September 03, 2011, 04:48:35 pm »
thankx Davey thats got my mind going now got to say I like Gantus idea so simple and small
Andy
Page created in 0.197 seconds with 18 queries.
