Author Topic: MMM Rosgarth - info please.  (Read 3641 times)
barriew
« on: March 15, 2007, 04:20:36 pm »
I am building MMM's Rosegarth. I collected the fittings last weekend and am now trying to work out which way to fit the Rope Hawsers - see picture. Does Part A or Part B go inboard?
Barrie
BlazingPenguin
Re: MMM Rosgarth - info please.
« Reply #1 on: March 15, 2007, 05:07:37 pm »
Part 'A' goes outboard, is trimmed to fit thickness of hull + thickness of washer. Washer glued on after!
barriew
« Reply #2 on: March 15, 2007, 05:48:22 pm »
Thanks - wasn't quite sure.
Barrie
andywright
« Reply #3 on: March 15, 2007, 08:48:55 pm »
Part  'B' goes outboard, honestly, I am a tug skipper. sometimes on more modern tugs with the more power to size ratio there are  four webs on part 'A'  at 6  and 12 o clock and at 3 and 9 o clock to the tugs bulwarks for strength. Don't put 'A' on the outside it will catch abnd snag on every thing the tug goes along side.
Regards Andy
Navigational Aids vessel Master. Old Conway 70-72
Peranos
« Reply #4 on: March 15, 2007, 10:45:46 pm »
 :( You're both wrong. Part A is fitted from the inside and part B is fitted over the bit of part A that protrudes through the hull on the outside. When part A is trimmed flush with part B, there is a nice smooth profile on the bow that nothing can be damaged by or caught up on.
John P.  :)
norry
« Reply #5 on: March 16, 2007, 07:32:16 am »
A goes Inside...B slips over the outside edge of A and  A is  then filed down flush to make nice ring on the outside...
If Fitted the other way round It will catch on everything the tug goes alongside...
I,ve built a few of Brians boats...
You can see one in place on the port aft bulwark of this tug...
barriew
« Reply #6 on: March 16, 2007, 10:05:23 am »
OK, the consensus is that A goes inside. Its difficult to see black on black, but Norry's picture makes it clear.
Thanks,
Barrie
BlazingPenguin
« Reply #7 on: March 16, 2007, 10:50:24 am »
the leg bones connected to the...hip bone...the hip bones connected to the...neck bone..the neck bones....Oh build it yourself? ???
Page created in 0.013 seconds with 18 queries.
