Author Topic: Some expert advice, please...  (Read 5304 times)
Patrick Henry
« on: October 28, 2011, 09:39:33 pm »
Ok, just going through my list of bits to get for my Gemini cat...
I want to change the horrible wooden framework that holds the two hulls together and supports the main mast for carbon rod...but(here comes the question)where do I get carbon rod and what sort of diameter would I need?
This is how I'm thinking of doing it....
Instead of this...
Any advice, guys?
tobyker
Re: Some expert advice, please...
« Reply #1 on: October 28, 2011, 10:49:32 pm »
I have been looking at Carbon rod for another project. It looks to me as if carbon tube might be a better bet for you - it would be stiffer and might be easier to fix at the ends. It's difficult to recommend a size as there's not much in the photos to scale them by.
john s 2
« Reply #2 on: October 28, 2011, 11:08:34 pm »
Just possibly an old fishing rod may provide what you require.John.
Patrick Henry
« Reply #3 on: October 29, 2011, 07:48:33 am »
Sorry, my mistake...I should have written 'tube' instead of 'rod'...
Fishing rods...I tried a old rod I found, but the sections are tapered, aren't they?
Patrick Henry
« Reply #4 on: October 29, 2011, 08:51:19 am »
It's been suggested that alloy tube from B&Q will do the job nicely, so I'm going to try that first, I think.
unicorn
« Reply #5 on: October 29, 2011, 09:12:49 am »
                  Look for a shop that specializes in selling kites.
        unicorn
richald
« Reply #6 on: October 29, 2011, 09:28:11 am »
try
http://www.giantcod.co.uk/carbon-fiber-tube-hollow-d60%C3%83%C2%97106050%C3%83%C2%971m-5pcs-p-403653.html
if you cast around on the GiantCod website you'll find they do 3mm and 6mm tubes and strip and rod too
Richard
Patrick Henry
« Reply #7 on: October 29, 2011, 09:50:37 am »
Now we're getting somewhere...thanks Richard!
I guess 6mm would be the size to go for to make up the cross spars?
CJ1
« Reply #8 on: October 29, 2011, 10:00:16 am »
The r/c helicopter guys use a lot of carbon fibre tube and rod. look on their websites.
Try here:
http://www.easycomposites.co.uk/Category/Carbon-Fibre-Products/Carbon-Fibre-Tube.aspx
Chirs
tony23
« Reply #9 on: October 30, 2011, 10:52:44 pm »
cheapest place for carbon tube would be a kite supplier model shops tend to ask the earth for carbon stuff.
http://www.thehighwaymen.co.uk/acatalog/Single_line_kites.html
Patrick Henry
« Reply #10 on: October 31, 2011, 02:01:05 am »
Thanks for all the valuable help chaps, it's much appreciated.
I think carbon tube may be the way to go, I'm told to think lightness above the waterline, weight below.
Thanks again,
Subculture
    • Dive-in to Model submarines
« Reply #11 on: October 31, 2011, 10:10:31 am »
Carbon fibre will be less than a third of the weight of aluminium.
I would go for the giant cod 6mm stuff. The kite shop CR tubing looks like it is a thicker laminate- stronger but heavier.
Patrick Henry
« Reply #12 on: October 31, 2011, 10:20:19 am »
All done...just bought the Giant Cod 6mm stuff, more than enough there for the cross pieces and maybe even the mast as well.
Thanks everybody,
richald
« Reply #13 on: October 31, 2011, 10:34:37 am »
Glad to help Rich,
Could you post some photies when you've finished ?
cos I've been thing about building a catamaran with
carbon fibre tubing to hold the hulls together
Richard
Patrick Henry
« Reply #14 on: October 31, 2011, 11:20:03 am »
No problem Rich...I'll take plenty of pics as I go along. It's only a cheapie of a kit, but I think with a few mods along the way we can do something with it. I chose it because it's only a small boat, it fits in my flat and my car nicely, and our local lake isn't really big enough for big boats.
