Pages: [1] 2 3   Go Down
Author Topic: 46 inch fibre glass hull  (Read 15814 times)
OapPETE
« on: November 09, 2011, 09:40:18 pm »
I am building a 46 inch model based on the moonraker do to thickness of fiber glass ( 4 /5 mm) thick it is quite heavy I would like to fit electric motor and was recommened to give Action Electronic`s from a member awile ago I rang him today but he think I need brushless motor to give it adequate power and he recommened I asked again on this forum he said a member called Nick75 is well up on brushless motors so Nick if you pick this up or anyone else on the forum I would be thankfull for any advice. Peter
MikeA
Re: 46 inch fibre glass hull
« Reply #1 on: November 09, 2011, 10:15:22 pm »
46 inch eh big boat that, especially for a fast one. Ill help a bit but first we got to decide how many props you want and what kind of budget your working too?
OapPETE
« Reply #2 on: November 09, 2011, 10:47:21 pm »
Hi Mad Mike
                  I am open to your suggestions I was going to use a 40 HP IC engine when I started to build it 30 plus years ago but then left it and now have decided I would prefer to go for electric I have one prop shaft fitted at the moment but could remove it if needed to, As for cost hit me with your suggestions and approx cost I always have expensive ideas  Peter.
« Reply #3 on: November 09, 2011, 11:01:08 pm »
My most expensive idea was definitely the wife and Kids  O0
Seriously though I'm interested in watching your topic but I don't have alot of experience - so any clear explanations will be read with much appreciation  :-))
Regards Dave
MikeA
« Reply #4 on: November 09, 2011, 11:15:31 pm »
what size prop you got on it?
OapPETE
« Reply #5 on: November 09, 2011, 11:31:42 pm »
No prop fitted just the shaft I think it would take 55  or 60mm  not sure will check tomorrow as it is in the loft where I do the building I think it is a 4mm
irishcarguy
« Reply #6 on: November 10, 2011, 08:53:33 am »
Hi Pete, Dave from ACTion will help you a lot & though he is a business he does not play games with your money,he also does nice wiring diagrams if you ask him nicely.LOL. MadMike is a very helpful guy & so is F1. With this kind of help & other members of the forum also, you will not go wrong. I must say I am totally clueless when it comes to the fast stuff, tugs are my speed, just thought I would throw in a little bit of reassurance for good measure. Mick B.
Mick B.
MikeA
« Reply #7 on: November 10, 2011, 02:57:13 pm »
well to power a boat of this size youl need to put a bit of money in it. it will be in excess of 100 pound at least. me perisonally am a budget builder so here was i would use. Other people will disagree:
motor
http://www.ebay.co.uk/itm/RCS-Model-C5055-700-KV-Outrunner-Brushless-Motor-OM190-/270642153758?pt=UK_ToysGames_RadioControlled_JN&hash=item3f0387891e
brushless esc:
http://www.ebay.co.uk/itm/SEAKING-120A-Water-Cool-Ship-Brushless-Motor-ESC-SL168-/270646728447?pt=UK_ToysGames_RadioControlled_JN&hash=item3f03cd56ff
4s lipo:
http://www.ebay.co.uk/itm/Turnigy-nano-tech-5000-mah-4S-25-50C-Lipo-Pack-/260877760875?pt=UK_ToysGames_RadioControlled_JN&hash=item3cbd86b96b
if you go lipo youl need a balance charger, these prices vary depending on quality but expect to pay around the 20 pound mark. if you get this one:
http://www.hobbyking.com/hobbyking/store/__5548__IMAX_B6_Charger_Discharger_1_6_Cells_GENUINE_.html
you will need a wall acdc adapter. there is another one on the same site with the adapter built it if you want to spend a bit more:
http://www.hobbyking.com/hobbyking/store/__6478__IMAX_B6_AC_Charger_Discharger_1_6_Cells_GENUINE_.html
anyway thats what i would do. If you dont want to go down the lipo route it is possible to use nimh or even a lead acid battery but they might add weight.
MikeA
« Reply #8 on: November 10, 2011, 03:38:24 pm »
there is another way and instead of using a 4s lipo use a pair or 2s lipos of the same type and make. If you then decide to up the speed you just add an extra one in.
for example 2 of these and then 1 more to make a total of 6s. that would probably make your boat stupidly fast lol
http://www.hobbyking.com/hobbyking/store/__17252__Turnigy_nano_tech_5000mah_2S_35_70C_Lipo_Pack.html
with these smaller batteries you can use these smaller cheaper chargers. youl need a 12v 1amp adapter for it though:
http://www.ebay.co.uk/itm/Turnigy-2-3cell-lipo-Balancer-Charger-same-day-post-UK-/130543016626?pt=UK_ToysGames_RadioControlled_JN&hash=item1e64f85ab2
OapPETE
« Reply #9 on: November 10, 2011, 03:45:14 pm »
Hi Mad Mike tried to send reply and 3 photo`s but have got to reduce size so it failed to send will try again thanks for info Peter.
OapPETE
« Reply #10 on: November 10, 2011, 07:56:39 pm »
Still having problem`s posting trying to send 3 photo`s
MikeA
« Reply #11 on: November 10, 2011, 07:58:19 pm »
cant understand it how are you uploading the pictures?
OapPETE
« Reply #12 on: November 10, 2011, 08:11:08 pm »
Click on Additional Options click attach  -- browse, double click on photo it attach photo number then add more attachments , browse and so on till I have 3 numbers when I click send
OapPETE
« Reply #13 on: November 10, 2011, 08:15:34 pm »
It come up internet explorer cannot desplay the web page
OapPETE
« Reply #14 on: November 10, 2011, 08:28:32 pm »
Mick B I spoke to Action he said I would need brushless motor and he recommended I asked on forum for help as he did not do brushless thanks for reply Peter
MikeA
« Reply #15 on: November 10, 2011, 08:29:48 pm »
no dont do that. click add image to post. its under the smileys when you reply
MikeA
« Reply #16 on: November 10, 2011, 08:53:38 pm »
pic. this was just a test its nothing relevant
OapPETE
« Reply #17 on: November 10, 2011, 09:02:17 pm »
MikeA
« Reply #18 on: November 10, 2011, 09:05:24 pm »
very nice. whats it like working in the attic? i might be shoved up there out of the way.
what do you think to that list i gave you too?
OapPETE
« Reply #19 on: November 10, 2011, 09:25:08 pm »
There is plenty of room up there it is like another room just a bit restricted with height at back of worktop do to slope of roof but is better than out in the garage in the winter.
It sounds confuseing but with help I think I will go for one or the other
« Reply #20 on: November 10, 2011, 09:51:10 pm »
Don'y know much about brushless, however Dave (Action) does a brushed 900 motor which on 24 V (and his big speed controller) would make your boat fly, and you would get a run time (at full chat as it were) of over 1/2 hour (I know because I have the set up in a straight runner, and Stavros stuck one in a 46 in perkasa) scary stuff
Hope it helps a little
MikeA
« Reply #21 on: November 11, 2011, 09:27:35 am »
pete i found this vid of a 49in perkasa with a 900 motor on 24v. if you went this route it would be a lot cheaper than brushless.
http://www.youtube.com/watch?v=fp3RNTVk1z4
« Reply #22 on: November 11, 2011, 04:23:13 pm »
You should put the same in that nice narrowboat hull  %% %%
MikeA
« Reply #23 on: November 11, 2011, 04:28:10 pm »
lol i was just posting a pick using the "additional options" button as ive not done it that way yet. it was just a test to see if it works, that narrow boat hull is just a pick of the net. thought about making one in the future  :o
Ade the Blade
« Reply #24 on: November 11, 2011, 09:19:25 pm »
Hi all i see we are back on the worlds fastest barge ,go on who will be the first to do it and a vid for all to see .Still on a serious note i watched the vid and have to say i was well impressed i may have a change of mind as to how to power my own 40in hull brushed my be the river to go down and save a few quid in the process i will watch this thread with interested ps Hi Mike .
Regards Adrian
Pages: [1] 2 3   Go Up
Page created in 0.221 seconds with 18 queries.
