Well I'll be there from Friday morning til close of play on Sunday. Will be camping on site though I might just end up sleeping in the car if weather's dodgy! Not sure what boats I'll be bringing if any as I'll have just moved house again for the second time this year!
I'm also going to be busy with the frequency board all weekend which is planned to be located by the ATBoatyard Type 45 HMS Daring.
 PLEASE NOTE:
PLEASE NOTE:  Frequencies
won't be able to be block reserved for the duration of the day or weekend, sailors will be expected to take it in turns if wanting to use the same channels. We strongly reccomend if on 40mhz or 27mhz you bring a selection of crystals.
Also it has to be pointed out that even if you're not 'on the water' but are intending to use your radio system that you first check that nobody is already using that frequency, please check on the 'board' first and book the frequency out.
Alternatively the use of a 2.4ghz system would solve the problem (we do understand that isn't an option for submariners).
Thanks, Dave. (Number 6)
