Author Topic: More Microballoons  (Read 3787 times)
wullie/mk2
More Microballoons
« on: November 19, 2011, 08:42:32 pm »
One more microballoon related query. What consistency should the balloon/resin mix be. I realise the resin will thicken up, but I guess it needs to self level, like a coat of paint.
I don't want to mix in too little and loose the advantage given by the microballoons when sanding.
Wullie,s place is an apology free zone
andrewh
Re: More Microballoons
« Reply #1 on: November 21, 2011, 12:53:50 pm »
Terry
That's a bit of a "piece of string question"
The microbaloons are light but weak, and the resin is dense but strong, so every different mix is a combination of these
It you want a sort of "varnish" coat, you need just enough baloons to make the resisn cloudy
If you need a really "filler" material, you put in enough to make a good paste which won't slump
I think your answer (to fill the weave of a finishing glass cloth) is mix in enough to make a single-cream consistency - still brushable.  Paint or scrate it on very thin, sand and be prepared to do it again :}
andrew
wullie/mk2
« Reply #2 on: November 21, 2011, 03:18:28 pm »
Hi Andrew, thanks for the advice, very helpful. I will consult the wife regarding the "single cream consistency" {-) Actually I am building the yacht for her so maybe she can contribute to the build by doing this mix!!
Cheers, Terry.
More Coffee
« Reply #3 on: May 07, 2012, 10:18:25 pm »
I use talc to thicken resin..otherwise known as baby-powder
Page created in 0.033 seconds with 18 queries.
