Author Topic: 24v ESC.  (Read 3389 times)
chugbug
24v ESC.
« on: March 26, 2007, 10:00:17 am »
Hi all, can anyone point me in the right direction for a 24volt esc. Also require an idiot proof description on connecting two 12v batteries to give 24volts.Why ? dont ask, its an age thing.
Dave.
boatmadman
Re: 24v ESC.
« Reply #1 on: March 26, 2007, 10:02:43 am »
Electronize do esc's that go up to 24v.
For 24 volts from 2 12 v batteries, connect the negative (black) connection on one battery to the positive(red) connection on the other battery and you have 24v across the two remaining unconnected terminals.
chugbug
Re: 24v ESC.
« Reply #2 on: March 26, 2007, 10:08:19 am »
 ;D  Thanks Ian, much appreciated,
                                              Dave.
Tug
Re: 24v ESC.
« Reply #3 on: March 26, 2007, 10:11:05 am »
speed control  easy Electronize rated at 30 amp continuous not the light one about £40 ish
Batteries for 24 volts
 red terminal [and wire] to speed control through switch and fuse from battery 1.
black on battery no 1 [--],  1 to red on battery 2,  black on battery 2 again through fuse and switch to speed control
 you will need separate receiver battery pack with this speed control.  4.8 - 6 Volts
Boy I wish I could remember how to do the picture thingie.  Tug
Update, can now do pictures,  ;D
Junk is something you've kept for years and throw away three
 weeks before you need it.
Re: 24v ESC.
« Reply #4 on: March 26, 2007, 10:42:26 am »
I gotta ask, why 24 volts?
High voltage for model boat.
chugbug
Re: 24v ESC.
« Reply #5 on: March 26, 2007, 12:06:54 pm »
hi Bob,  because I got a 24v motor given.Daft or what?
Thanks Tug for the tip about separate receiver pack would never have thought of that.
 Dave.
chugbug
Re: 24v ESC.
« Reply #6 on: March 26, 2007, 12:11:46 pm »
Hi again Bob, should have phrased that better,meant me daft or what,not you
 ;D ;Dave.
BobF
Re: 24v ESC.
« Reply #7 on: March 26, 2007, 01:09:04 pm »
Hi chugbug,
You will probably find that the motor works just as well on 12 volts.
A lot of the motors we use are rated higher than the voltage we give them.
If you use 24 volts, it will probably be too powerfull, and you will have to have the speed controller at just above stationary position. Also, it's not good for a controller to be used on the slowest setting, as they get hotter that way.
Tug
Re: 24v ESC.
« Reply #8 on: March 26, 2007, 03:41:43 pm »
Bob,
for the bigger tugs 12 Volts just ain't man enough.
Joffre on 6 volt 4 amp and overpowered,
Drifter on 6 volt 12 amp would like 7.2 cause the bec drops out sometimes,
Re: 24v ESC.
« Reply #9 on: March 26, 2007, 03:50:17 pm »
I put 2 x car blower motors in a RMAS Roysterer on 12 volts.
I had never seen an ocean tug plane till then  :) I had to go down to 6 volts.
Model Motors Direct do some good motors for tugs at reasonable prices.
With 24 volts you will have to ensure the wiring is up to the job too or you could have an electric heater inside your model.
It just seems rather excessive.
     http://www.electronize.co.uk/model_electronics_frames.htm
Try this link.
