Author Topic: Motor Supressors  (Read 2791 times)
Tralee
Motor Supressors
« on: March 28, 2007, 08:59:17 pm »
I have recently purchased from Model Slipway a Drumbeat of Devon model kit.
I intend running this on two Graupner 600 Eco 7.2v motors, do these motors require supressors? and if so any help with type  and supplier etc would be appreciated
Stan
Re: Motor Supressors
« Reply #2 on: March 28, 2007, 11:56:09 pm »
Hi Trailee
Its is advisable to install all motors with suppressors  you will req 3 in total  one between the motor terminal's and the other 2 from each motor terminal to motor can. the value of these should 104 pf  any good model shop should have these in stock  if not contact  all components  on  01981 540781  also very good for small bulbs and cable also  hope this helps. Do you have a Maplins shop in your area if so you will be able to get them there. :)
Stan
Stan
« Reply #3 on: March 29, 2007, 12:01:20 am »
Hi Trailee
Fogot  to tell you type of capacitor s you will req   ceramic  or ceramic dipped  also  i think you may be able to get these from  S.H.G model supplies. :) :) :)
Ian Robins
« Reply #4 on: March 29, 2007, 12:02:00 am »
Hi Trailee
most of the graupner motors i have come across have internal suppressors.
But if you are not sure then I dont think that fitting another set will hurt,
but then someone on here will correct you if I am wrong.
ro88o
Page created in 0.162 seconds with 17 queries.
