Hello Minardifans and welcome
QUOTE:
I love DIY projects as I'm into my model railways and such so I was thinking of scratch building a hull to start with. I was looking at some other members on here have used Plastic as a frame before planking with plastic also and then coating in Fiberglass. The question I have is wether or not you need to use the fiberglass sheet or can you just use the resin liquid on it's own or are there other resins that you can use that don't require using a weave.
I've got a basic idea of shape and plan in my head and some sketches on paper, just need to think about waterproofing before I go any further.
QUOTE
If you are familiar with plastic assembly - go for it! I have made several boats with styrene because it was available for free, builds fast and gives a good finish.
You can (depending on the actual hull shape you have in mind) make the planking fairly watertight without any further covering. People do this and bung up any leaks with the same plastic dissolved in solvent.
You can bond glass strips inside the hull for strength, or cover the outside with glass (or nylon stocking, or horticultural fleece!), andf you can stick it with virtually any adhesive including fibreglass resin. Or emulsion paint - but prolly not pva glue as it is marginal on water-resistance for this application
Tell us, please your intentions
Having an interested son is a very valid reason to have a boat to
play with sail seriously
andrew
