Author Topic: Brushless for bow thruster?  (Read 2368 times)
Tug Fanatic
« on: April 10, 2012, 09:02:11 am »
I am making a bow thruster for a tug that would normally use a soft 540 motor driving racing type prop in a 40mm waste pipe:
http://www.modelboatmayhem.co.uk/forum/index.php?topic=1592.msg15848#msg15848
Unfortunately I need to keep the whole istallation as short as possible and also to run the motor at 12v. Would someone be kind enough to recommend a physically small brushless outrunner motor that will turn a slightly cut down 40mm racing prop?
As an aside there is a lot of information about brushless motors & aero props but nothing about boats. Is there a sensible way of using the aero data for boat props?
nick_75au
    • Logan City Marine Modellers
Re: Brushless for bow thruster?
« Reply #1 on: April 10, 2012, 10:05:17 am »
A 28 mm X 22 mm (KA22-20) 1000 Kv, (try to find a lower Kv if possible) motor will do that, or if you can fit a 42 mm diameter motor that's about 20 mm thick a DT700 or DT750.
Answer to Q2, not that I have found {:-{
Nick
Tug Fanatic
« Reply #2 on: April 10, 2012, 12:27:07 pm »
Thanks for the help. Pity about the aero prop info.
Page created in 1.46 seconds with 17 queries.
