Author Topic: huntsman  (Read 6859 times)
triumphjon
Re: huntsman
« Reply #25 on: April 24, 2012, 06:53:24 pm »
depending on your set up  i did post on the other thread ( spearfish requirements ) a week or two ago a full set of dimensions for fitting both the propshafts and rudders through the hull , my own models are twin shaft , & the motor/s are fitted in the same position as they would be on a full size fairey huntsman 31 / spearfish
Re: huntsman
« Reply #26 on: April 25, 2012, 06:17:21 am »
Thats great thanks...
is the 30mm from propshaft to hull skin measured from the centre of the propshaft or the top? my proptube is 8mm in diameter so its a 4mm difference
triumphjon
Re: huntsman
« Reply #27 on: April 25, 2012, 08:19:53 am »
i normally measure from the centre of the propshaft , to the hull skin .
Re: huntsman
« Reply #28 on: April 25, 2012, 09:30:49 am »
I thought so but just wanted to double check
The precident instructions are a little sparse when it comes to the prop shaft install
triumphjon
Re: huntsman
« Reply #29 on: April 25, 2012, 02:46:15 pm »
note , my shafts are much shorterthan the original precedent recomendation , my motors are below the open cockpit , ive opened  the section behind the air scoops on the cabin sides and made some internal ducting which forces a small amount of air down towards the motors ,
HawkEye
Re: huntsman
« Reply #30 on: May 07, 2012, 07:22:00 pm »
:-)) thanks bluebird just got off the phone to them they are going to do a detail kit for the huntsman for about £10 -£15 dont think thats bad got to ring back tomoz to find out what they are putting in the kit will post on here as soon as i find out once again cheers mate
dave
Is there any update to add to this thread yet jacko, waiting in anticipation  :-)
HawkEye
I've never been so sure of something I wasn't sure of...
Re: huntsman
« Reply #31 on: May 07, 2012, 11:47:17 pm »
Maybe some pix too please?
Page created in 0.684 seconds with 17 queries.
