Author Topic: Grease propshaft ???  (Read 6375 times)
carpfisher
« on: April 29, 2012, 03:51:11 pm »
Hi Everyone wonder if you could advise me please ?
I have an Anatec mono boat that's used in Angling this has a Graupner 600eco motor and I think its a Graupner shaft too
now it has a thin red plastic tube that the makers sell you a  aerosol of lubricant you fit onto it and give a few squirts while the motor is turning slowly its a blue sort of colour but the tin is plain white and costs £10 plus postage
I am sure if I knew exactly what to but I could buy it cheaper but being a novice I don't have a clue ?
I DO KNOW if I forget to do it water comes in the boat  any Tips advice or recommendations would be great  thanks for reading
'Life isn't about how to survive the storm, but learning how to dance in the rain
nemesis
Re: Grease propshaft ???
« Reply #1 on: April 29, 2012, 04:58:00 pm »
Hi, It could be liquid PTFE. The clever lads use it on their club 500s. Nemesis
« Reply #2 on: April 29, 2012, 05:03:46 pm »
I know I bang on about this when ever this topic comes up...........but I have to say.......My Clyde lifeboat running Loch Ness last year was the only boat not to leak water..........I used vaseline mixed with carbon powder and injected into the tubes around the shafts.......and the stub tubes were only 6" long....they were totally watertight, and I use this method on all my boats....the inner ends of the tubes are usually below waterline level as well. :-))
carpfisher
« Reply #3 on: April 29, 2012, 06:25:01 pm »
Hi well it needs to be an aerosol tin to be able to squirt it down the plastic tube that fits the aerosol tin ?
john s 2
« Reply #4 on: April 29, 2012, 06:40:57 pm »
What colour is the spray liquid? Graphite is dark. Does the can have any indication of whats in it? I belive you said the can is plain. Surely a responsible seller would list contents as it may use a flammable propellent and have a poisonous content. Have you asked the supplier what is in it? If they are selling it id hope theyed know. John.
carpfisher
« Reply #5 on: April 29, 2012, 06:43:19 pm »
No nothing at all on the can its plain white  the colour of the greasy liquid is blue ish
The boat is made and sold in France its an ANATEC Mono  and is used to take out bait and your hook  far beyond casting range in large french lakes  :}
« Reply #6 on: April 29, 2012, 07:02:55 pm »
You were lucky, vaseline is water soluble.
gwa84the2nd
« Reply #7 on: April 30, 2012, 12:09:10 pm »
i would just use some ptfe spray grease available at most diy shops  :-))
Peter Fitness
« Reply #8 on: May 01, 2012, 12:04:41 am »
I use outboard motor grease which is unaffected by water, but you may have trouble getting it into a thin red tube.
Peter.
HS93 (RIP)
  • I cannot spell , tough
« Reply #9 on: May 01, 2012, 12:43:39 am »
I wish someone would go through the posts and put all the posts on this subject all together because it must have come up 20 or 30 times and every time the same people put there views forward and every time they are all different and every time someone gets stroppy because they think there idea is right,pin it at the top of this section ,
Oh and put on a few drops of three in one down the oiler if you have a shaft at an angle for when you run it out of the water O0
Peter
HS93 (RIP)
Peter Fitness
« Reply #11 on: May 01, 2012, 07:05:12 am »
I wish someone would go through the posts and put all the posts on this subject all together. Every time someone gets stroppy because they think their idea is right.
Peter
I doubt if anyone has enough free time to do that, Peter, even though it is a good idea. I haven't noticed anyone being stroppy on this thread yet, though, people are simply making suggestions.
Peter.
catengineman
« Reply #12 on: May 01, 2012, 08:56:56 am »
Cycle chain lube
come in a can with a small pipe on the nozzle and with a little length of silicone tube it can be injected into oilier tubes
has worked for me on my builds
dodgy geezer
« Reply #13 on: May 01, 2012, 12:32:35 pm »
Or, alternatively....
Timo2
« Reply #14 on: May 01, 2012, 12:44:23 pm »
Hi All
     Now my twopence worth  try a UK base company goods  Eg :-  http://www.actioncan.com/type/511/WG-90-White-Grease---PTFE-General-Purpose-Formula
     As said by others  " it works for me "
    OK
 Timo2
Just a Buoy at heart
carpfisher
« Reply #15 on: May 09, 2012, 10:42:14 pm »
many thanks again lads I will go with the last suggestion and get some WG 90
sounds good
god bless Gerry  :-))
Page created in 0.186 seconds with 18 queries.
