When the large lifeboats were initially fitted with radar, the mast was on the centreline. However, if the boat was fitted with an airbag when it was modified to self-righting then the mast was either moved to the port side or fitted to the roof. The boats that were built for slipway stations had a folding mast so the boat could fit in a low boathouse, while those built to stay afloat had fixed masts fitted.
This is the fixed mast as fitted to Frederick Edward Crick. Unfortunately, as the radar mast was not an as-built fitting, it doesn't appear on any General Arrangement plans. Also, I've not found any official RNLI drawings either. Therefore the dimensions for the folding mast were taken off the mast fitted to RNLB North Foreland, a 46ft 9in Watson, as it was the same fitting.
Here is mine after painting:
And here's a slight problem I found after carefully painting both the mast and the surface it sat on. On the real boat, as the two fixing rails of the mast are flat, and they're fitted to a curved surface, there is a black gunk that's used to fill the gap. Now, trying to be smart, I put cling film over the boat to protect the paint, put a layer of filler onto the cling film and pushed the mast onto it, to get the right curvature. What I didn't know was that after the filler had set, and I tried to pull it off, the filler had EATEN AWAY THE PAINT beneath it. I had to remove the whole area and repaint it. I didn't try that again.
By the way, if anyone wants a copy of the drawings of the mast and the radar I can have them scanned and email them.
Andrew
