I will strip away most of the paint in immediate areas.
What kind of 'seal' would you use or have in mind?
The 'light glass cloth' I thought of using comes from Halfords - do you
know the type? Light enough?
And end up coating inside with a layer of resin.
Nordlys.
Hi Nordlys,
This is what I call light cloth:
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=10903I can't get that at the local Halfords, they only carry polyester and non woven glass, the stuff to repair car bodies, unsuitable for your purpose.
"Most of the paint" will only work if the structure of the wood is visable, as epoxy doesn't bond well with paint.
I'd repair the cracks with 24h epoxy resin, sand the repaired spots back into shape and cover the entire hull with glasscloth end 24h epoxy resin.
Don't attempt to glass a hull with the 30 minute stuff, that's how long it'll take to set completely, the 24h epoxy gives you that long to work with it...
I have recently covered my 110 cm wooden M.A.S. with glasscloth and epoxy; as the edges needed to stay sharp (glasscloth can't be forced around a tight radius anyway, not without vacuumbagging that is), I worked each flat(ish) surface separately, leaving a small overlap:
As you can see the structure of the glasscloth is still visible after the first layer.
Once cured, the cloth is cut with a sharp knife and sanded flush with the adjacing surface, which is covered next with glasscloth and epoxy.
This leaves you with a hull with razorsharp edges:
When all surfaces have been covered in (at least one) glasscloth, adding two more layers of epoxy resin will fill the weave, smoothening the surface, no filler needed:
I sanded through the glasscloth on several spots, so these had to be re-done:
After light sanding and a few coats of epoxy, the hull is smooth all over.
If you work with 24h epoxy and you have the time to add another layer within 24h, you won't have to sand and degrease between layers, as you'll have sufficient chemical bonding.
Letting the epoxy cure in a warm surrounding allows you to add more layers in a shorter time, I managed three surfaces in a day, the entire hull took five days.
Regards, Jan.
