Pages: [1] 2 3   Go Down
Author Topic: Pat Tritle's Yoda's Ark  (Read 21144 times)
escipion
« on: October 11, 2012, 08:15:58 pm »
Hello!!!
A few months ago, I started to build the Pat Tritle’s Yoda’s Ark. The plan recommends to do it with 1/8” balsa, but it doesn´t makes me very happy; never construct a boat with balsa and feel like it could be somehow fragile, so I decided to make it with 1/8” plywood
Here I send you a pic of the framework.
escipion
Re: Pat Tritle's Yoda's Ark
« Reply #1 on: October 11, 2012, 08:18:00 pm »
Here I started the planking
escipion
« Reply #2 on: October 11, 2012, 08:25:25 pm »
After planking the sides with ramin wood strips (sorry, don’t know the name in English), I decided to use 1/16” ply to plank the bottom.
escipion
« Reply #3 on: October 11, 2012, 08:30:44 pm »
I choose to make a solid balsa block for the front instead of planking. As it’s going to be covered with fiberglass, feel like it’ll work out well.
escipion
« Reply #4 on: October 11, 2012, 09:26:31 pm »
Some wood filler before sanding
escipion
« Reply #5 on: October 11, 2012, 09:29:39 pm »
Here we have the hull completed before fiberglassing
escipion
« Reply #6 on: October 11, 2012, 09:39:35 pm »
Fiberglassing, I choose to use 2 oz fiberglass cloth and pacer z-poxy finishing resin
escipion
« Reply #7 on: October 11, 2012, 09:41:43 pm »
Here you have it after the first coat
escipion
« Reply #8 on: October 12, 2012, 04:44:48 pm »
The boat needed two more coats of finishing resin and a session of sanding. As it’s going to be painted, at the end I put some paste and another session of sanding (95%of the paste will go away)  :-))
Big Ada
« Reply #9 on: October 12, 2012, 05:44:40 pm »
We know it as Ramin in the UK also, but as it is classed as a Special Hardwood we are unable to get it any more.
Len.
escipion
« Reply #10 on: October 18, 2012, 07:20:52 pm »
Thank you very much for the information Len, didn´t know about that restriction in UK.
After sanding the paste I decided to begin painting her, the first thing is to put the primer. I’ve been using DuPont’s automotive paints in some of my other boats with excellent results, so decided to use it once again
escipion
« Reply #11 on: October 18, 2012, 07:21:48 pm »
By the time I finished with the primer, I noticed that didn’t put the ruder tubes, so before plying once again the primer build the tubes with their base.
escipion
Benches
« Reply #12 on: October 18, 2012, 07:24:31 pm »
I was a little bored with the hull, so decided to build the benches. I thought they was too simple so decided to change them a little, changed the style and made them with Crispy-Kreme Wooden Stirrers Coffee Mixers and here is what I’ve got.
escipion
« Reply #13 on: November 05, 2012, 04:31:17 pm »
 Hello!!!!
A little more work. As I don’t have a place especially for my buildings, it’s been a little difficult to me to paint the hull, so decided to work in the main deck. I saw some wooden yachts using two kinds of wood, so determined to use Zapelli and Manzonia in the planking of it
As it was finished the planking of the main deck I put two stringers of mahogany.
By now I’m painting the hull and making the propellers, I’ll tell you about when it’s finished
Best regards
« Reply #14 on: November 05, 2012, 06:43:30 pm »
Progressing well you are young padawan :)
escipion
« Reply #15 on: November 06, 2012, 04:51:25 pm »
Thank You Master  :embarrassed:
« Reply #16 on: November 07, 2012, 12:54:42 pm »
with a name like Yoda's ark someone had to  :embarrassed:
escipion
« Reply #17 on: December 04, 2012, 06:05:38 pm »
 Hello!!!!
I’ve been working in some parts of the boat as time permits me.
I’ll show you how I made the propellers, mainly used two materials, 1/8” collars and 0.9 mm brass.
First, with the dremel,  I made two 30 degrees grooves in the collars
I made each blade with the 0.9 mm brass and solder with tin to the collar
Sorry about the Pic, doesn’t  make justice to the propellers
escipion
« Reply #18 on: January 04, 2013, 11:27:47 pm »
Hello!!!!
I’ve been working a little more, by now I made the cabin, all in mahogany, here is one pic.
escipion
« Reply #19 on: January 04, 2013, 11:33:29 pm »
I’ve been painting the hull; I’m using automotive DuPunt’s enamels and primer (more or less 6 coats of each color), by now I have to wait about two weeks in order to apply a coat of urethane
Best regards
vnkiwi
« Reply #20 on: January 04, 2013, 11:40:33 pm »
Coming on very nicely.
Well done
cheers
vnkiwi
escipion
« Reply #21 on: January 05, 2013, 12:54:22 am »
Thank you very much vnkiwi
I forgot to tell you about painting the hull; I’m using automotive DuPunt’s enamels and primer, more or less 8 coats of each color, plus sanding.
By now I have to wait about two weeks in order to apply a coat of urethane
hazegry
« Reply #22 on: January 13, 2013, 02:49:52 am »
Nice work man any updates?
escipion
« Reply #23 on: January 16, 2013, 04:02:52 am »
 Hello!!!!
By now I applied two coats of urethane, I’ve been sanding and using wax, almost finished, and then, I’m planning to install the running hardware. Sorry don’t have pictures of my work, it’ll almost look the same.
Best regards
escipion
« Reply #24 on: January 28, 2013, 07:34:18 pm »
 Hello Guys
I’ve been working in the hardware. Here in México, there are few places to buy hardware and fitting, the most are for airplanes, I only know one decent store who sale things for boats, but is too far away, so sometimes I have to do those things myself. That’s the arms case, I had to build them both using 1/8” collars and 0.9 mm brass and the results work well but I think the next time could do it better
Here I send you a picture of the rudders hardware with the servo
As you can see in the picture, I found the advice of a marine expert
Best regards
Pages: [1] 2 3   Go Up
Page created in 0.159 seconds with 18 queries.
