Pages: 1 [2] 3   Go Down
Author Topic: 48" X cat design and build  (Read 17998 times)
F1 madness
Re: 48" X cat design and build
« Reply #25 on: February 27, 2014, 03:26:37 pm »
Well finally getting there
Topdeck is now moulded just needs trimming and will add some wood to back it up ,just gotta leave it now for a week or so to fully cure before splitting and prep the bottom for moulding  :-))
gwa84the2nd
« Reply #26 on: March 01, 2014, 05:30:39 pm »
top notch  :-))
F1 madness
« Reply #27 on: March 18, 2014, 08:01:47 am »
Made 1st hatch for this build,only thin layup to break in the mould but also 1st time test fit and check clearances round the engine ,fits nice and clearance is not an an issue so pretty happy ;)
Also now moulded the bottom of this build,fingers crossed releases ok in a week or so ,then wont be long before laying up and pulling the 1st hull ;)
F1 madness
« Reply #28 on: March 27, 2014, 05:35:51 pm »
Having really good day today and very happy
Released the 48" X-cat moulds even the plug/hull came out on 1 piece lol
Ill spend a couple days now wet sanding and polish them all up
F1 madness
« Reply #29 on: March 27, 2014, 05:37:48 pm »
Got them all wetsanded and polished up ready to start waxing
Hopefully layup 1st hull next week ;)
F1 madness
« Reply #30 on: April 03, 2014, 12:36:47 pm »
Layed up 1st hull and joined just leave it few days now to cure,hopefully will release ok and ill start building it up ready for testing ;)
F1 madness
« Reply #31 on: April 03, 2014, 12:39:50 pm »
Joined
F1 madness
« Reply #32 on: April 03, 2014, 12:42:05 pm »
Just placed engine and exhaust in hull while still in moulds so while letting it cure I can make a start on the stringers and transom plate and check clearances ;)
Modified the exhaust to get a better tune length
F1 madness
« Reply #33 on: April 04, 2014, 01:18:57 pm »
Moulded new hatch Monday and released today and started trimming it up using original build,fits nice so pretty happy so far :-))
F1 madness
« Reply #34 on: April 05, 2014, 09:46:58 pm »
The cats out the bag :} {-)
F1 madness
« Reply #35 on: April 06, 2014, 11:06:41 pm »
Started fitting hardware,finished the stringers & transom plate and setting out for correct CG placement
F1 madness
« Reply #36 on: April 06, 2014, 11:09:47 pm »
Stringers & transom plate now fibreglassed in and sorted radiobox so thats ready to fit in
F1 madness
« Reply #37 on: April 07, 2014, 05:08:20 pm »
Coming along nicely, all cutting and drilling is now done
Final trimmed hatch opening Cut and fitted stainless scoops, 1 short but on order haha
Grab handles,exhaust and water outlets fitted, holes drilled for cooling pipes
Front hatch hold down tab done
Start installing everything now :-))
F1 madness
« Reply #38 on: April 07, 2014, 06:52:07 pm »
Starting to install everything now Fuel secured and pipe work sorted,installed rudder and cooling pipe,made a piece to hold cooling and filler side of fuel pipes tidy and away from exhaust & engine rails in
F1 madness
« Reply #39 on: April 07, 2014, 07:20:39 pm »
Engine and exhaust installed,fuel & cooling pipes plumbed in[/size]Also changed the carb to 1048 see how it runs with this on to start with
[/size]
F1 madness
« Reply #40 on: April 07, 2014, 09:12:24 pm »
Nearly there now
Driveline in and radiobox ,couple bit n pieces to finish off and ready for bench test
tmbc
    • www.tmbc.org.uk
« Reply #41 on: April 07, 2014, 09:23:12 pm »
cant wait to see it go ! looks the dog danglies !  {-) {-) O0 O0 :-))
BMPRS  Health and Safety Co-Ordinator
F1 madness
« Reply #42 on: April 07, 2014, 09:44:25 pm »
Neither can i bud ,will be a steady run start with while breaking in engine and start setting it up  :}
« Reply #43 on: April 07, 2014, 10:16:51 pm »
F1...the outer edge/length/diameter of the exhaust tune pipe would appear to be in close proximity to the hull side wall
We see a small amount of 'fire sleeve' on the exhaust manifold [is it only protecting the water cooling tubing?]....but will the hull get any additional heat protection?..............Derek
F1 madness
« Reply #44 on: April 07, 2014, 10:21:58 pm »
Hi derek
Theres plenty of room round it bud theres about 2.5" between the exhaust and side of the hull aswell ,just pics dont show it clearly ;)
F1 madness
« Reply #45 on: April 08, 2014, 05:01:58 pm »
Started the engine for 1st time ,2nd pull it fired straight up so well pleased ,no major issues
http://www.youtube.com/watch?v=X408mVNA6Ac&feature=share&list=UUaL9d4jUpBXPgaKCz3ASTow
Also decided to make slight mod and allow more exhaust heat out ;)
F1 madness
« Reply #46 on: April 08, 2014, 07:15:37 pm »
ALL DONE
Apart from vinyl and getting it on the water and setting it up shes ready to race  :-)) :}
Danny
  • Gorleston Model Boat Club
    • Gorleston MBC
« Reply #47 on: April 08, 2014, 10:39:30 pm »
Another beautiful boat Daz - and a masterclass in tidy building!
Wish you every success with it.
Danny
F1 madness
« Reply #48 on: April 09, 2014, 08:21:15 am »
Thanks Danny  :-))
Will get an idea of how shes runs on sunday but breaking in new engine so will be steady racing
Boyd also racing the 38" V2 cat aswell so will be fun day setting up and sorting out  {-)
F1 madness
« Reply #49 on: April 09, 2014, 05:02:13 pm »
Little project for today
Pages: 1 [2] 3   Go Up
Page created in 0.027 seconds with 18 queries.
