Pages: 1 [2] 3 4   Go Down
Author Topic: Cragsider Build  (Read 25249 times)
chipchase
Re: Cragsider Build
« Reply #25 on: May 30, 2013, 09:53:36 pm »
The next part of the build was the stern roller I use a metal tube and turned the end caps using alloy and the pins are made from brass
chipchase
Re: Cragsider Build
« Reply #26 on: May 30, 2013, 10:24:58 pm »
The stern end was cut and brass plates fitted to support the roller, the end caps are made from brass tube shaped and a brass bush fitted inside for the roller pins to fit into.
chipchase
Re: Cragsider Build
« Reply #27 on: May 30, 2013, 10:48:08 pm »
And finally rubbed down and primed.
dreadnought72
Re: Cragsider Build
« Reply #28 on: May 30, 2013, 10:49:53 pm »
Exquisite!
(There's a word I don't use everyday!)
Andy
Howard
Re: Cragsider Build
« Reply #30 on: May 30, 2013, 11:27:29 pm »
Brian,
When are you going to write a book so we may all learn from your skills.
 I cant find the words to say how much enjoyment I get from watching your builds.
                 Thank you for shareing them with us.
                       Regards Howard.
chipchase
Re: Cragsider Build
« Reply #31 on: May 30, 2013, 11:41:14 pm »
Thank you Howard for your kind comments, but I am afraid that I am not very good at putting words together so I don’t think I will be writing a book. (I will have to stick to building models) {-) {-)
Re: Cragsider Build
« Reply #32 on: May 31, 2013, 01:11:19 am »
chipchase .......pictures say a 1000 words...so......just keep them coming  O0
BTW...are they M2 brass hex headed bolts retaining the quarter deck cover plate over the drive gear?........... Derek
tugnut
Re: Cragsider Build
« Reply #33 on: May 31, 2013, 05:58:02 am »
Very neet Brian, your builds are so interesting ,keep pict coming.
regards John
Umi_Ryuzuki
    • Models and Miniatures
Re: Cragsider Build
« Reply #34 on: May 31, 2013, 07:06:33 am »
Really great work.
chipchase
Re: Cragsider Build
« Reply #35 on: May 31, 2013, 09:10:51 am »
Thanks for the positive comments. :-)) Yes Derek the plate pertaining bolts are 2mm hexagon headed brass bolts, the holes were drilled and tapped. unfortunately I don’t have a photo showing the deck frames under the stern plate, when I drilled through the alloy plate I also drilled into the deck frames this also secured the deck and inspection plate.
chipchase
Re: Cragsider Build
« Reply #36 on: May 31, 2013, 11:00:59 pm »
Here are photos showing the Sampson posts, I made the posts out of 12mm alloy.
chipchase
Re: Cragsider Build
« Reply #37 on: June 01, 2013, 10:52:45 pm »
Here are three photos showing her fully primed.
chipchase
Re: Cragsider Build
« Reply #38 on: June 04, 2013, 09:49:48 pm »
Here she is with her final coat of paint  :-))
mark w
  • "I stick my neck out for nobody"
Re: Cragsider Build
« Reply #39 on: June 04, 2013, 09:55:33 pm »
Lookin' great  :} .
Mark
"If she can stand it, I can too, play it"
Brian_C
Re: Cragsider Build
« Reply #40 on: June 04, 2013, 09:58:13 pm »
 very nice brian,,,, looking real good,   exellent build so far, :-))
chipchase
Re: Cragsider Build
« Reply #41 on: June 04, 2013, 10:21:57 pm »
Cheers gents here are a few photos showing the superstructure and the handrails. I will post some photos showing the superstructure build.
mark w
Re: Cragsider Build
« Reply #42 on: June 04, 2013, 10:52:06 pm »
Mark
chipchase
Re: Cragsider Build
« Reply #43 on: June 05, 2013, 09:34:20 pm »
Here are the latest build photos.
Howard
Re: Cragsider Build
« Reply #44 on: June 05, 2013, 09:50:20 pm »
Brian, as I was born and lived in Hebburn till my early twentys you bring back so many memories.
             Regards Howard.
chipchase
Re: Cragsider Build
« Reply #45 on: June 05, 2013, 10:35:21 pm »
You will have seen her many times going up and down the river  Howard, I still have the main winch and windless to build so if anyone has some good close up photos of them it would be much appreciated. :-))
Regards Brian
pdryden
Re: Cragsider Build
« Reply #46 on: June 05, 2013, 10:46:48 pm »
Lovely Build Brian, a real proper tug with character, look forward to seeing it soon  :-)
chipchase
Re: Cragsider Build
« Reply #47 on: June 07, 2013, 12:04:42 am »
Cheers Peter, as promised her are a few photos showing how I built the superstructure.
Re: Cragsider Build
« Reply #49 on: June 07, 2013, 04:41:07 pm »
Can you clarify your pictures Chipchase.  Did you make a wooden frame for the cabin first, and then use it to construct the plastic shape around it  ?  It looks like the wood has been removed.
Ken
Pages: 1 [2] 3 4   Go Up
Page created in 0.501 seconds with 18 queries.
