Author Topic: motor and esc problem  (Read 3599 times)
bigun108
  • hard to get bits sent to Malta
  • alot of helpfull sea dogs on here
« on: May 22, 2013, 04:03:03 pm »
Im having problems with my esc I have connected the esc (bec) to the battery then connected the esc to the motor but I have no power to the motor how can this be please
its a hard life
Mad_Mike
  • Lincolnshire
Re: motor and esc problem
« Reply #1 on: May 22, 2013, 04:19:58 pm »
check the plugs and connections, wiggle them around. If not check the voltage of the battery, if not that check you have the right battery polarity connected.
bigun108
« Reply #2 on: May 22, 2013, 04:26:21 pm »
thank you I have tried most ways I think and all my joints are soldered I have put a tester on the motor connection and nothing would you suggest  the esc is duff  thanks
its a hard life
hmsantrim
« Reply #3 on: May 22, 2013, 04:33:40 pm »
hi there.
       What make of s.con is it.
              Frank
bigun108
« Reply #4 on: May 22, 2013, 04:38:15 pm »
its a EL 110amp model from Australia ............shaun
its a hard life
Jerry C
« Reply #5 on: May 22, 2013, 04:49:00 pm »
You didn't mention the receiver?
Jerry.
bigun108
« Reply #6 on: May 22, 2013, 04:52:32 pm »
this is the set up I have jerry 2.4G 6CH Radio Model RC Transmitter Receiver FS-CT6B
its a hard life
« Reply #7 on: May 22, 2013, 05:29:20 pm »
Has the ESC got a small slide switch and is it switched on?
Does the receiver operate the rudder or any servo?
bigun108
« Reply #8 on: May 22, 2013, 05:31:13 pm »
no switch ned  and it works servos ......shaun
its a hard life
unbuiltnautilus
« Reply #9 on: May 22, 2013, 05:31:19 pm »
And just check your not plugged into the battery socket on your Rx, trust me, it happens %)
bigun108
« Reply #10 on: May 22, 2013, 05:42:45 pm »
call me thick thick thick I was lol well just a great big thank you guys I do appreciate it just on the up side Malta is 82 today and now thanks to you people (experts) im off out to have a beer in shorts n t shirt  ......once  again  THANK YOU!!!!!!
its a hard life
« Reply #11 on: May 22, 2013, 06:02:44 pm »
So what was the problem?
Jerry C
« Reply #12 on: May 22, 2013, 06:03:47 pm »
There you go.
Jerry.
« Reply #13 on: May 22, 2013, 06:06:49 pm »
Sounds like UBN hit the nail on the head again :-))
Don't disturb a man and his beer >>:-(
 O0
bigun108
« Reply #14 on: May 22, 2013, 06:07:50 pm »
JERRY YOUR A STAR ill have a pint for you
its a hard life
bigun108
« Reply #15 on: May 22, 2013, 06:10:41 pm »
perfect ned lol
its a hard life
Page created in 0.327 seconds with 18 queries.
