Author Topic: 1/12 Severn  (Read 3419 times)
paul1985
1/12 Severn
« on: May 29, 2013, 09:40:27 pm »
Hi everybody
I am building a speedline 1/12 severn and I am using the plans from the rnli
And Adrian says that the measurements on the plan should be times by 1.66 but if I scanned
The part of the plan I was working on and enlarged it by 1.66 would that then give me the correct
Size for the hand rails in 1/12 scale for me then to print out
Paul
craggle
  • Boaty McBoatface
Re: 1/12 Severn
« Reply #1 on: May 30, 2013, 09:19:59 am »
What scale are the RNLI plans drawn at?
Craig.
Model Slipway Envoy tug built.
Huge Lifeboat under construction.
paul1985
Re: 1/12 Severn
« Reply #2 on: May 30, 2013, 09:34:15 am »
They are Drawn at 1/20 scale
vnkiwi
Re: 1/12 Severn
« Reply #3 on: May 30, 2013, 09:39:58 am »
Yep,
from 1/20 to 1/12 multiply by 1.6666
cheers
vnkiwi :-))
john44
Re: 1/12 Severn
« Reply #4 on: May 31, 2013, 10:18:21 am »
Having been there and done that on my Trent,
It is a lot easier and better all round to have the
whole plan enlarged to 1/12, rather than parts of it.
then you can form and build whatever
to the plan. It is very easy to forget the x 1.666 when
engrossed in building believe me.
john
Peter Fitness
Re: 1/12 Severn
« Reply #5 on: May 31, 2013, 10:56:42 am »
I have a set of Severn plans from the RNLI, courtesy of our own Tug Kenny :-))  and one sheet is to 1/25 while the others are to 1/20 {:-{  I't a project that's been on the back burner for quite a while now, but the time is growing closer. I will build it to 1/20 scale, so I will need to have the 1/25 sheet re-sized.
Good luck with your Speedline build Paul, and I look forward to some photos.
Peter.
  • I love lifeboats,but don't tell the wife!!
    • Phils Rc Models
Re: 1/12 Severn
« Reply #6 on: June 01, 2013, 09:08:32 am »
If you take the measurement from the drawing x it by the scale that will give you full size then divide by 12 so on the 1/20th scale drawing,
20mm x 20 =400mm / by 12 =33.3mm. if the have the drawings blown up to 1/12th scale you need to check them before excepting as true scale, the hulls are or should be within a 1mm tolerance, so take that measurement with you and check the drawing if its not right? get them to adjust it, also if you do have them done remember that the drawing line will also be bigger, so go from the centre of the line not the outer edge.
Phil.
Page created in 0.034 seconds with 18 queries.
