Author Topic: crane bolts and nuts  (Read 4740 times)
para_handy
« on: June 12, 2013, 11:39:50 am »
I am about to build a crane for the back of my model boat Star Perseus can anyone tell me hoe to simulate the nuts and bolts rather than buy a lot's of expensive brass ones???????????
mermod
Re: crane bolts and nuts
« Reply #1 on: June 12, 2013, 12:51:37 pm »
Evergreen styrene do a hexagonal strip that's perfect for that, also K&S did a brass version but not sure if its still available.
What size are you doing your Star Perseus? I have a bit of a soft spot for her :-))
People who think they know everything are a great annoyance to those of us who do.
Isaac Asimov
mermod
« Reply #2 on: June 12, 2013, 01:13:13 pm »
I just used good old brass rod for mine, nobody ever notices.
Isaac Asimov
nemesis
« Reply #3 on: June 12, 2013, 04:25:15 pm »
Hi, Do not spoil your ship for a half penny o tar. Nemesis
GAZOU
« Reply #4 on: June 12, 2013, 05:18:08 pm »
I bought 148 nut 1mm to put on a boat.
I sold my shirt to buy nuts.
Once painted you can not see anything ................... {:-{
The faces of the nuts are very small, too small.
Keep your shirt and put the stems as Mermod :-))
Mermod !beautiful crane! it work?
garethjones35
« Reply #5 on: June 12, 2013, 08:57:07 pm »
There is a company called Kit Form Services who can supply a set of photo etched nuts and bolt heads.  They come in a variety of sizes from 0.8 to 2.0 mm AF.  They have a UK website where you can get full details.  There is also a Chinese company called Lion Roar who make all sorts of photo etched bits and pieces for super detailing models and they also do photo etched nuts and bolts.  They are available through various modelling suppliers on the web.
Gareth
« Reply #6 on: June 12, 2013, 11:00:15 pm »
I have a couple of etch sheets left over from an abandoned model I was building (1/35 scale model loco that made a suicide dive from the top shelf)
I think there are some nuts on it.
Roughly what size you need
mermod
« Reply #7 on: June 12, 2013, 11:02:09 pm »
Yes Gazou the crane works, small pneumatic ram, rock crawler winch (see the wire not connected) and a high torque servo below deck through a belt system for the swivel.
Phill
Isaac Asimov
red181
« Reply #8 on: June 13, 2013, 12:01:49 am »
how small do you need, its a nice model so dont spoil it at this stage, these are 12ba, dirt cheap, from model train suppliers
colin
« Reply #9 on: June 13, 2013, 07:09:41 am »
You could try these in the states and not cheap but have a good range
http://www.scalehardware.com/miniature-rivets-c-10
Born free Taxed to death.
GAZOU
« Reply #10 on: June 13, 2013, 08:01:16 am »
Hello Mermod
you have a pneumatic cylinder.
the progressive movement? Or brutal? How did you do?
Do you have a photo of the boat?
Do you have a video of the crane?
Many questions! %)
mermod
« Reply #11 on: June 13, 2013, 11:17:46 am »
Hi Gazou, I have a small industrial air pump with an on or off switch, the movement was quite brutal but I now have a small regulator tap to cut the pressure back (hard to photograph right under the deck), the arm only stays up if the power is on and drops pretty quickly when I cut the switch. I use a Futaba 9cap with rotary dial for rotating the whole assembly and the winch came with a fwd and back control that plugs into any channel on the radio.
Hope this isn't seen as hijacking the original post :embarrassed:
Isaac Asimov
para_handy
« Reply #12 on: June 13, 2013, 11:37:35 am »
Carry on mermod you have not hijacked lovely pics
GAZOU
« Reply #13 on: June 13, 2013, 11:46:13 am »
 think the air is still a little rough.
It is very difficult to adjust
on my supply my friend made ​​hydraulically and operation is very smooth and powerful.
It is possible to lift 11 kg
mermod
« Reply #14 on: June 13, 2013, 11:48:20 am »
Can I borrow your friend ?
Isaac Asimov
GAZOU
« Reply #15 on: June 13, 2013, 01:07:04 pm »
Oh là là !
if you want to borrow my friend we will have to borrow the woman!!!
It is like a shadow....................; >>:-(
no it is not true! it is delicious
Page created in 0.425 seconds with 17 queries.
