Pages: 1 2 3 4 5 [6] 7 8 9 10 11 12 13   Go Down
Author Topic: 1/12 Arun lifeboat  (Read 124900 times)
baloo
  • I`M YOUR FRIENDLY TRUCKER
Re: 1/12 Arun lifeboat
« Reply #125 on: November 16, 2013, 04:43:18 pm »
Hi Dave,somebody on here somewhere said try robosizer and it does everything for you,i tried it and it works.I think it`s in the section about downloading photo`s.
Martin
baloo
« Reply #126 on: November 16, 2013, 04:48:30 pm »
Hello again Dave,it is in chit-chat section under photo resizing,page 10,then look for netleyned.
kinmel
« Reply #127 on: November 16, 2013, 04:53:29 pm »
Thanks Alan, I like that idea of using the pump now and again, so as I have never used scoops before were are these best placed .
Regards Dave.
Ideally in the water flow through the propellors, but with the lifeboats anywhere deep inside the tunnel has a fast enough water flow.
Good luck tomorrow.
« Reply #128 on: November 16, 2013, 05:02:59 pm »
Robosizer works for me.
Just set it for large email and
as you pick a photo from your files
it automatically resizes it .
Simples :-))
mersey dave
« Reply #129 on: November 16, 2013, 05:25:05 pm »
Thanks Martin and Ned will give it a try. :-)) :-))
Regards Dave.
mersey dave
« Reply #130 on: November 16, 2013, 05:29:55 pm »
Good luck tomorrow.
Thanks Alan I get what you mean, ........no tunnels on the Arun though but as long as I get a good flow it should cool them enough. :-))
Regards Dave.
luke1993
« Reply #131 on: November 16, 2013, 09:21:58 pm »
mersey dave
mersey dave
« Reply #133 on: November 17, 2013, 01:28:22 pm »
Hi all, had the Arun out today for trials, she was running on 14.8 volts 8ah lipo battery and did it go .........very fast but the good thing was it runs at approx  quarter throttle for about two hours and the low battery alarm had still not sounded. So as things stand I am very happy .......it looks impressive on the water, so now I can crack on getting the hull ready for spraying. :-))
Regards Dave.....PS sorry no photo's I was so keen to get to the lake I forgot the camera.
kinmel
« Reply #134 on: November 17, 2013, 02:19:34 pm »
Well done Dave
Now the hard part starts  :-))
mersey dave
« Reply #135 on: November 17, 2013, 02:31:51 pm »
Thanks Alan, it was people like yourself who persuaded me to go brushless plus I had seen your Tamar and how well it went, so on to the hull now.  :-)) :-))
Regards Dave.
Rottweiler
« Reply #136 on: November 17, 2013, 03:20:14 pm »
I shall be putting brushless outrunners in my 1/12th scale Tamar,and have been assured by a well know Lifeboat builder that I do not need cooling,so that is the way I intend to go?
Mick F
« Reply #137 on: November 17, 2013, 03:25:15 pm »
Cracked it Boyo :-))
Speed and run time, a perfect combination.
Now you have to spend two years making it
look as good as it goes.
luke1993
« Reply #138 on: November 17, 2013, 03:40:15 pm »
 check your camera like mine does and many more digital cameras there is a email setting.
I have a small button press it and email comes up on lcd screen auto sizes the pics ,works for pics on here too don't have to fuss about with other programmes.
just a suggestion as I never knew I had this function until I played with camera and mines only a cheapish sony 8.1 mgp
about 8 years old so sure modern cameras have this too
cheers
mersey dave
« Reply #139 on: November 17, 2013, 04:33:45 pm »
Thanks Ned, it's now as you say a lot of work ahead to make it look as good as it goes but that's the part I enjoy, I just do a bit at the time as there's no rush. :-))
Regards Dave.
mersey dave
« Reply #140 on: November 17, 2013, 04:40:22 pm »
Mick F
Hi Mick, this is the first for me so I could not advise anyone but as far as cooling I would think at little more than tick over things are not going to get that warm.......I shall keep an eye on them and see how things go.
Regards Dave.
« Reply #141 on: November 17, 2013, 04:47:07 pm »
Paul Red181 is the chap to talk to about cooling brushless. He did a lot of research and development with the late HS93. His cooling continues post run because of latent heat transfer problems.
mersey dave
« Reply #142 on: November 17, 2013, 04:51:54 pm »
Thanks Dave, I have a lot to learn on this brushless setup mate. :-))
Regards Dave.
pipster
« Reply #143 on: November 17, 2013, 05:15:42 pm »
I'm running brushless on my 1/16 Tamar.  I was assured by the shop I bought the motors and ESCs from that there's no need to water cool. It's only had a couple of trial runs and so far so good.  They certainly infinitely cooler than the brushed set up on my Trent.
Phil
mersey dave
« Reply #144 on: November 17, 2013, 05:26:50 pm »
Phil
Hi Phil, I would of thought that if they were run at full throttle for long period's of time then yes it would be wise to water cool them, but as I found today it was far to fast on half throttle so the rest of the time it was going round on little more than tick over so I would think they will be OK .
Regards Dave.
imsinking
« Reply #145 on: November 17, 2013, 07:16:56 pm »
I was at the lake today , an impressive turn of SPEED  %%  from such small motors (outrunners) I've been wary of LIPO's & Brushless . . . maybe it's time to join the new order  :embarrassed:  , one thing tho' does an E S C work harder at low throttle settings  as it's regulating the power , while at full throttle the powers just going straight thru ? I've never given it a thought . . . .
Bill
mersey dave
« Reply #146 on: November 17, 2013, 07:34:18 pm »
Bill
Hi Bill, I would have thought the E S C would have to work harder at high speed which would demand higher amps resulting in them getting hotter...........maybe someone will let us know for sure. :-))
Regards Dave.
McGherkin
« Reply #147 on: November 18, 2013, 12:17:45 pm »
Yes, as far as I know it's high speed running which generates heat in ESCs, as mentioned due to the amps.
mersey dave
« Reply #148 on: November 18, 2013, 01:35:54 pm »
Thanks mate, that's what I thought. :-))
Regards Dave.
mersey dave
« Reply #149 on: November 19, 2013, 08:19:12 pm »
Hi all, all the brass rod I had on order has arrived so tomorrow I shall have a go at making the railings .
Any tips would be most welcome. :-)) :-))
 Regards Dave.
Pages: 1 2 3 4 5 [6] 7 8 9 10 11 12 13   Go Up
