Author Topic: glue  (Read 2349 times)
spike
glue
« on: September 25, 2013, 01:50:17 pm »
what glue to use for wood to fibreglass please
SailorGreg
Re: glue
« Reply #1 on: September 25, 2013, 02:04:51 pm »
Epoxy works for me, Araldite or similar for small jobs or one of the many other two-part epoxies, with fillers if needed, for large jobs.  If it's a very small, non-load bearing part on to the gel coat (smooth) side then superglue will probably work, but make sure the surface is cleaned properly.
Greg
TailUK
Re: glue
« Reply #2 on: September 25, 2013, 02:50:16 pm »
A small amount of the lay-up resin will give a very strong join.  If you didn't lay the hull up your self, Epoxy or a gel super glue.
StarLocAdhesives/FiveStar
    • StarLoc FiveStar quality adhesives and glues at FMK
Re: glue
« Reply #3 on: September 25, 2013, 04:36:11 pm »
Always sand the inside surface of fiberglass due to the wax added to prevent air inhibition during cure
After sanding, the best glues would be something like flexy cyano ( rubber toughened cyanoacrylate ) or a toughened methacrylate such as our ` super acrylate ` , epoxys would also work but are not quite as strong as methacrylates or toughened cyanoacrylates on composites
If using standard fiberglass polyester resin , as its quite low strength with no fillers , to get strength use it with a long fiber filler such as chopped glass strands or a piece of glass cloth
Formulators and manufacturers of quality adhesives and surface coatings for industrial , DIY & modelling sectors since 1988
See us online   www.shop-4-glue.com
on ebay https://www.ebay.co.uk/sch/gianthairyhedgehog/m.html?_nkw=&_armrs=1&_ipg=&_from=
Page created in 0.227 seconds with 17 queries.
