Pages: 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 ... 28   Go Down
Author Topic: M/P Nuova Loredana Italian Fishtrawler  (Read 246631 times)
Perkasaman2
Re: M/P Nuova Loredana Italian Fishtrawler
« Reply #25 on: September 04, 2015, 01:27:06 am »
Cad is not easy to learn from scratch and views are limited to the screen monitor  size which in my view is a severe handicap. Drawing half frames on tracing paper are also easily flipped to give reversed images which can be traced through to produce whole sections or frames. Missyd already has various plans of the boat ready for use. The frame drawings are ready to transfer to timber when construction starts. Ultimately an accurate side elevation plan will give the correct height relationships of the frames to create the correct overall  keel and deck outine shapes.I am enjoying the thread and watching the project take shape.
Unsinkable 2
« Reply #26 on: September 22, 2015, 09:21:31 pm »
I always draw on paper too, I just like creating a drawing that you can unroll and show people what you drew and then the product that came from it.
 I really do appreciate the skill involved with CAD though and if it was available to me some years ago then I might have taken it up, but I'll stick to drawing for now....... U2
It'll look better when it's finished!
« Reply #27 on: September 22, 2015, 09:32:23 pm »
I did learn some CAD back in the ninties, but being the usual know it all teenager/just twenty something, I beleived that it would not have much effect on the small design/model making business.
Wrong! I do wish I had kept it up and would probably use it in my new hobby today, but I do like a roll of plans and there is something comforting about the pencil and a good eraser. I can certainly see the pros of drawing on a 'pooter' but think that a larger screen would be beneficial.
missyd
« Reply #28 on: October 26, 2015, 05:34:29 am »
The building starts ....
9mm plywood
the sections copied and cut out ...
and two sections cut out with my new proxxon bandsaw wich does the job very well.
Danielle
« Reply #29 on: October 26, 2015, 08:38:09 pm »
I love the smell of birch ply! Your frames look pretty good Missy!
« Reply #30 on: October 26, 2015, 09:23:47 pm »
Hullo Danielle...............if that's the straight cut line & surface you get from the Proxxon band saw it must be worth its weight in gold :kiss:...do you use the standard 14 TPI blade, or the flame hardened shorter length version?.....especially to attain those inner radius surfaces so cleanly
They are about $500.00 in Australia  >>:-(............. Derek
missyd
« Reply #31 on: October 27, 2015, 04:33:03 am »
Thanls a lot ! I use the original blage that was already with the bandsaw. Its very fine and the cuts cleaner as with any saw I used in the past. The price is quite expensive even here in switzerland.
Danielle
Mad Scientist
« Reply #32 on: October 27, 2015, 09:13:06 pm »
Danielle,
I hope that is not BLOOD in your photo of the plywood!
Tom
missyd
« Reply #33 on: October 28, 2015, 05:47:28 pm »
Tom ... I cut my ex-mother-in-law into little pieces .... JUST JOKING!
No blood sofar .... its a sticker on the bandsaw ....  :-))
Danielle
missyd
« Reply #34 on: November 20, 2015, 10:01:07 am »
Some more work done .... hope you like it! ok2
Danielle
Big Ada
« Reply #35 on: November 20, 2015, 05:55:18 pm »
Ah, I spot a bowl of diet chips/French Fries in the 2nd photo up {-).
I like to see an economical us of material ( your cutting out of the Ply frames ).
I will be following this build as I did your previous one.
Kind Regards,
Len.
« Reply #36 on: November 20, 2015, 06:34:21 pm »
I do like to see plywood and love the smell. Those frames are very tidy and smoothly shaped Danielle.
Top job. I look forward to see more progress soon.
« Reply #37 on: November 20, 2015, 07:57:44 pm »
mmmmmmmmmmmm not sure the pussycat would like the....."chips/French Fries in the 2nd photo up {-)"......Derek
Mark T
« Reply #38 on: November 22, 2015, 03:54:49 pm »
For some reason I missed this thread when you started it Danielle but it looks like another cracking build - I'll be watching again  :-))   Good luck with it  :-) :-)
missyd
« Reply #39 on: November 23, 2015, 10:20:35 am »
thanks a lot Mark  :-))
Some more work done. fitted the prop-axle to see if I had drilled the holes at the right places. All where spot-on!!!
Pictures of the things I bought saturday in a shop in eastern switzerland.
Danielle
« Reply #40 on: November 23, 2015, 10:14:05 pm »
That is an interesting selection of motors and fittings Danielle. The hull scantlings are really sarting to look good.
missyd
« Reply #41 on: November 25, 2015, 07:56:51 pm »
Thanks a lot .... 2h work today ... I build the hull in sections. Rear section is finished. Middle one is 1/3 finished ....
Danielle
« Reply #42 on: November 25, 2015, 08:40:37 pm »
Well.......that appears to be an extremely robust hull frame construction Danielle  :o.......have you weighed all of the frames?
As a general question, I wonder what type of adhesive the manufacturers use on these types of laminations?, which are also appearing increasingly now also in complex V W V male & female grooves [finger] joints in wood that is destined for external surfaces in [expensive] semi-modern furniture
missyd
« Reply #43 on: November 26, 2015, 10:01:34 am »
No I didn't put the frames on a scale sofar .... there are more frames than on the FV Cornelia Marie which has a empty hull weight of 7-8kg
Danielle
missyd
« Reply #44 on: November 27, 2015, 04:02:35 pm »
new pics of todays work...
Danielle
Mark T
« Reply #45 on: November 27, 2015, 06:04:26 pm »
Nice carpentry there Danielle - Its looking great  :-))
missyd
« Reply #46 on: December 21, 2015, 10:39:54 am »
Thanks a lot Mark!  :-))
As I hadn't designed the bow sofar I decided to make one in 3D out of insulation material and then cut it into slices to get the right shape of the front sections. 1 Week of dirty work and the bow is ready to be sliced ....
Any knife or cutter can be used ....
After the first shaping session without even looking at the pictures of the bow ....
After the second and final shaping session---
Danielle
jarvo
  • Etherow model boat club
« Reply #47 on: December 21, 2015, 09:29:13 pm »
HI Danielle, the foam blocks do make shaping the bow form so easy, are you covering with glass cloth???
Mark
Tugs are for pulling
missyd
« Reply #48 on: December 21, 2015, 09:44:11 pm »
Hi Mark. Actually no. I have cut everything into slices so that I can use them to finish the drawings .... The Hull will be made of plywood as usual ....  ok2
Danielle
jarvo
« Reply #49 on: December 21, 2015, 09:50:16 pm »
Does that mean you are putting formers into the bow area then planks????
Mark
Pages: 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 ... 28   Go Up
Page created in 0.024 seconds with 19 queries.
