Pages: 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 ... 28   Go Down
Author Topic: M/P Nuova Loredana Italian Fishtrawler  (Read 236849 times)
missyd
Re: M/P Nuova Loredana Italian Fishtrawler
« Reply #175 on: July 07, 2016, 03:56:26 pm »
Re-painted the hull red and it looks as the deformations have stopped.
Today I prepared my new toy ... its a Profiform 320 machine. It cut and bends alu, steel, brass, copper up to 1 mm. Costs a forunte but works just fine!
I also started to make the rudder. The rudder will be detachable from its axle.
Danielle
« Reply #176 on: July 07, 2016, 07:01:40 pm »
Awesome machine Dannielle! I nearly bought one a few years back and probably would have used it a dozen times in a decade but it will revolutionise your model engineering potential.
I can see you making live steam boilers and the like now  8)
missyd
« Reply #177 on: July 07, 2016, 07:41:02 pm »
Your right ... I have 3 live steam plans at home that I could build. All logging-railroad steam engines ...  ok2
Danielle
missyd
« Reply #178 on: July 08, 2016, 05:00:35 pm »
Some more work done to the rudder ...
Soldered together...
Added the lower axle ...
The konical shap holds the rudder in place but it also helps whe I want to detach it from the main axle .... I'll explain that later ...
And then I could try it out on the hull ....
The ribs 5 of them each side will be added next week ....
Danielle
« Reply #179 on: July 08, 2016, 09:23:43 pm »
Excellent Danielle. You are as good whittling metal as your are wood  :-)) Re Locomotive boilers, these were used in early steam powered vessels until specific marine boilers and the like came into use, so you could combine a locomotive boiler with a vintage ship!
missyd
« Reply #180 on: July 11, 2016, 05:51:53 pm »
No I wouldn't do a steam ship .... its not my favorite kind of model. But a steam loco or tractor would be much fun!
I nearly finished the ruder today ... quite difficult to solder everything on. Next step will be the connection to the ruder axle which has to be detachable.
Danielle
« Reply #181 on: July 11, 2016, 07:54:11 pm »
Lovely work Danielle. I like the ribbage:O)
jarvo
  • Etherow model boat club
« Reply #182 on: July 11, 2016, 10:14:57 pm »
Nice work on the rudder, bet there were a few swear words and scorched fingers LOL. The hull seems to have stabilized again, few. nice paint finish re-applied
Tugs are for pulling
« Reply #183 on: July 11, 2016, 11:45:45 pm »
You can be justifiably proud of that effort on the rudder - really smart looking, that is. O0
missyd
« Reply #184 on: July 12, 2016, 12:02:48 pm »
Thanks a lot you two!!!!  :-))
I said a few beeeeep words but no scorched fingers ... I used a wet towel around the ruder all the time.
The connection to the axle is made with a simple hex screw ... no fancy solution but it works just fine. The washers should simulate the connection system used on the origial ship.
Danielle
« Reply #185 on: July 12, 2016, 05:54:21 pm »
Looks good Danielle - most effective.
Good tip about using the wet towel as well O0
missyd
« Reply #186 on: July 13, 2016, 09:11:04 pm »
Thanks a lot Ray!!!!  :-))
Today I made the Net-Roll (don't know how this part is called in english)
Drawing .... actually I made it 180mm long.
A little bit working with my lathe ...
Looks ok!
Cutting an M3 thread ...
Looks even better ....
Need to make the attachment points and its finished!
Danielle
jarvo
« Reply #187 on: July 13, 2016, 09:44:24 pm »
Same in english Danielle, net roller to bring the net over the stern, this is better than CM, your multi functional skills are amazing
Mark
« Reply #188 on: July 13, 2016, 10:02:59 pm »
Have you a mill as well Danielle? If so, Hussar! Your engineering work looks splendid.
missyd
« Reply #189 on: July 14, 2016, 06:24:29 pm »
Yes I have a mill and a lot more nice machines ....  ok2
Made the net roller holder ....
Then I fitted the motor (geared 6:1), the propaxle and the connection axle-motor.
And to finish the day I filled the hull with 2kg of iron pellets. I need some 6-8 kg ballast to get the hull down to the waterline. As I don't know how heavy the superstructure will be I fitted these 2kg ballast.
Danielle
« Reply #190 on: July 15, 2016, 08:58:37 pm »
Excellent. I wondered what had happened to your hull for a second. It looked like a load of wood dust and was expecting a comment to such.
Limiting the quantity of ballast will help you keep it a bit lighter for moving it, good idea  :-))
Big Ada
« Reply #191 on: July 30, 2016, 05:22:09 pm »
It is coming on nicely.
Len.
missyd
« Reply #192 on: August 05, 2016, 04:06:56 pm »
Thanks  a lot you two ... I used 3kg ballast sofar. I may need another 3-5kg to get the hull deep enough into the water.
I wasn't happy with the quality of the hull color so I redid everything ...
Color samples I mixed ... the upper left one (ROST+...) was used.
I like this color as its not too red ...
Danielle
missyd
« Reply #193 on: August 06, 2016, 03:31:19 pm »
Today I went shopping for the RC equipment and other parts ...
More about the building next week ...
Danielle
« Reply #194 on: August 06, 2016, 08:35:13 pm »
I like it. The colour you have made is quite like red oxide primer but not too drab.
missyd
« Reply #195 on: August 09, 2016, 04:56:51 pm »
I just added some black and cherry red to the original paint (rust).
Now I started to paint the hull dark blue. Bought a lot of different colors till I got the right one!
I paint only part of the hull at the moment. because later I can't turn it upside down anymore. So I'll finish the paintwork before I build the rest of the boat.
Danielle
« Reply #196 on: August 09, 2016, 08:00:15 pm »
That is a good classic looking dark blue. I like it muchly:O)
jarvo
« Reply #197 on: August 09, 2016, 09:59:05 pm »
Very rich Dark Blue, looks great
Mark
missyd
« Reply #198 on: August 11, 2016, 05:12:57 pm »
I finished painting the hull a few minutes ago ... now I let it dry for e couple of hours!
6x  blue paint, 4x yellow paint and 2x waterproof polyethurane acrylic lacquer.
Danielle
jarvo
« Reply #199 on: August 11, 2016, 05:27:55 pm »
Very clean water line, which masking tape did you use??. Also did you clear coat the tape to stop any creep under???
Mark
Pages: 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 ... 28   Go Up
Page created in 0.173 seconds with 19 queries.
