Author Topic: M/P Nuova Loredana Italian Fishtrawler  (Read 247355 times)
cos918
Re: M/P Nuova Loredana Italian Fishtrawler
« Reply #350 on: November 30, 2016, 05:00:49 pm »
Hi Danielle
when I do LEDs I normally have X1 led and a 750 ohm resistor for 12v. For the micro LED about 1mm by 1mm Its needs to be higher like 1.5K ohm. all leds are wired in series .
john
missyd
« Reply #351 on: November 30, 2016, 07:39:10 pm »
Here the colcultions from the LEDs vendor homepage (in German)
Danielle
missyd
« Reply #352 on: December 01, 2016, 03:19:59 pm »
Done all the wiring for the Gantry and the lights for the working deck. I have to glue in the profiles that will cover the wires just like its done on the original.
Danielle
missyd
« Reply #353 on: December 02, 2016, 03:57:08 pm »
Finished the upper deck today .... a few details and color missing.
The exhaust stack was made and glued in.
And it looks like that from the inside.
Danielle
Big Ada
« Reply #354 on: December 02, 2016, 05:53:57 pm »
They look full size, lovely work. Are you staying at home for Christmas ?.
« Reply #355 on: December 02, 2016, 05:55:47 pm »
I agree. Except for the obvious plywood trunk, it does look spookily real. You and Joe have that knack  :-))
jarvo
  • Etherow model boat club
« Reply #356 on: December 02, 2016, 09:25:04 pm »
Tragic that most of that superb work will not be easily visible when complete. but you know its there, thats what counts
Mark
Tugs are for pulling
missyd
« Reply #357 on: December 05, 2016, 05:16:22 pm »
Thanks a lot!!!!  :-))
Today I made the deck openings for 2 ropes (to lift the net and cod end) and 4 cables for the 4 small nets that can also be used. The 4 small nets are a dragging type with fingers that scratch the bottom .... I wont model them.
Here a picture of them.
First I had to locate the exact positions of the openings.
Here you see where the openings will be. Exhaust stack will be at position marked with a W.
Openings ready to be made square and tidy.
Danielle
« Reply #358 on: December 05, 2016, 05:30:24 pm »
Well, you certainly have an eye for detail and the more you add, the more realistic this model will be.
Fascinating to see this boat coming together. O0
missyd
« Reply #359 on: December 05, 2016, 07:22:35 pm »
Thanks a lot Ray.  :-))
Here another picture of a yacht the Ippolito werft has designed and constructed.
I have seen this yacht myself and its very elegant!
Danielle
« Reply #360 on: December 05, 2016, 10:15:11 pm »
It has a good balance between style and practicality. Are you going to add some of the fish trays that you can see in the picture of the nets?
missyd
« Reply #361 on: December 06, 2016, 04:43:12 am »
I don't know if I will model the fish trays.
Danielle
missyd
« Reply #362 on: December 06, 2016, 06:15:12 pm »
Finished everything today!
Danielle
« Reply #363 on: December 06, 2016, 07:25:27 pm »
Hullo Danielle.......I seem to get auto e-mails from the German WEB De Sc--------. so viewed the winch wire shrouds there first
The shrouds do look very tidy indeed sectioning both the upper and lower deck levels.......however as noted a few days back, it seems a pity to hide the winches and attached wires away from view
I am sure you will have the opportunity during construction to rig a winch wire or two just to show the mechanism without the deck
kees de mol
  • crazy about shipbuilding
« Reply #364 on: December 06, 2016, 10:50:12 pm »
I walked trough the pages and I am amazed by what I see here. Very nice fishingboat.
Groetjes, Kees
missyd
« Reply #365 on: December 07, 2016, 04:43:07 am »
Thanks a lot!  :-))
The is an opening in the upper deck. It can be lifted out including the exhaust stack. So the winch will be totally visible.
Danielle
missyd
« Reply #366 on: December 09, 2016, 03:04:02 pm »
As you can see the exhaust stack is fixed to the deck opening. I made the tube detail today.
And the two pulleys where made too.
And the whole thing finished.
Danielle
« Reply #367 on: December 09, 2016, 08:33:34 pm »
Fantastic Danielle, you must be very pleased at how she has come out. Nearly there!
missyd
« Reply #368 on: December 10, 2016, 06:24:38 am »
Yes I am. But as usual I see a lot of mistakes .... modellers life ...
Danielle
RAAArtyGunner
« Reply #369 on: December 10, 2016, 10:41:52 am »
Stand further away it will look better O0 O0
Looking Good :-)) :-))
Mark T
« Reply #370 on: December 10, 2016, 03:26:05 pm »
Ahh I know this feeling well; the strive for perfection.  We are always the most critical of our own builds but I must say that you build looks amazing  :-))
missyd
« Reply #371 on: December 13, 2016, 03:44:52 pm »
Thanks a lot for the encouraging words!  ok2
Today I made some of the ropes needed for the N.Loredana ....
Length is about 4m.
First I made some with 3x1 ... normal yarn.
Then I made some with 3x1 fine yarn.
The next ones where made with 3x3 fine yarn with excellent results.
I also made one with 3x3 normal yarn with not so good results.
These are all ropes I made today.
(from the top left to right)
BLUE= 3x3 normal yarn, TAN= 3x3 fine yarn
GREEN= 3x1 normal yarn, WHITE= 3x1 normal yarn
TAN= 3x1 fine yarn
x
Danielle
Big Ada
« Reply #372 on: December 13, 2016, 05:43:11 pm »
Have a length of yarn/string/wool hanging down and a cat always appears out of nowhere. O0
Did you make the Rope Machine?.
Len.
missyd
« Reply #373 on: December 13, 2016, 10:21:28 pm »
Len.
Len, actually the cat wasn't interested in the yarn at all ....  ok2
I bought the rope machine online ... can't remember the shop .... I found another brilliant rope machine that will make professional looking ropes as long as you want.
It works just like the real ones I saw at work when I was working for the worlds #1 steel cable factory in Switzerland.
I may build a prototype with my Meccano parts and then build a sturdy one .... I wouldn't buy it from this page ... too expensive.
LINK ---> http://shipworkshop.com/products/tools/ropewalk-planetary-3.0
Danielle
Big Ada
« Reply #374 on: December 15, 2016, 06:23:33 pm »
There is a very old Rope Making Machine in the Ropery/Rope Walk at the Chatham Maritime Museum in Kent that is a Quarter of a Mile long and the workers use Cycles to get from one end to the other.
Page created in 0.033 seconds with 18 queries.
