Author Topic: This is my seaport tug after upgrades  (Read 7545 times)
rhardy67
« on: June 07, 2014, 05:36:58 pm »
Just changed out the toy electronics to hobby grade and i like how it turn out , put in a HOBBYWING QUICRUN WP1625 R/C Fwd & Rev W/BEC Brushed 100A ESC and Nx Metal Gear Digital 13kg Servo MG946 High Torque and using a FLYSKY Transmitter FS-GT2B 2.4Ghz radio system , stayed with stuck motor and using Traxxas powercell 5000 Manh nimh 8c battery . Hears a short video of it on water for the first time after upgrades http://youtu.be/NKHOni8Qvlo
This is a still work in progress  .
1 Traxxas Rustler VXL + HK Aquaholic rc boat and Seaport tug + Traxxas Slash 4x4 platinum + Pro boat Impulse 31 .
tugboat pete
  • TUGBOAT PETE
  • Im a tugger cos i pulled
Re: This is my seaport tug after upgrades
« Reply #1 on: June 14, 2014, 04:50:27 pm »
Hello there rhardy67 and welcome to mayhem you seem to be getting on with that mod i would advise to remove the ballast tank and isopon the inlets closed hope all goes well best regards. tugboat pete YAAAARG
rhardy67
« Reply #2 on: June 14, 2014, 06:22:00 pm »
Thought about removing the ballast tank but that where the battery sits  on . if i would remove it how much weight would i have to add ?
tugboat pete
  • TUGBOAT PETE
« Reply #3 on: June 15, 2014, 05:21:16 pm »
yes i understand but if you cut out the ballast tank use isopon p36 to fill the inlet slots you will be able to fit a battery lower into the hull im posting my ballast weights position you may find that you wont have to use so much taking into account the battery weight have a look at my posts on this mod hope all goes well good luck and keep on pulling YAAAARG.
rhardy67
« Reply #4 on: June 15, 2014, 05:36:30 pm »
The battery i use is a traxxas 8c 5000 mah nimh battery and is alot longer than what your use . mind sets on top of the ballast tray between the 2 blue strips of rc wheel weight .
rhardy67
« Reply #5 on: July 09, 2014, 07:52:08 pm »
Changed video . hear it is before an after upgrades .
http://youtu.be/5Ua4nmFsOBE
Page created in 0.229 seconds with 18 queries.
