Author Topic: Has anyone made a crane barge  (Read 2665 times)
fullboat
  • BORED........? BUILD ANOTHER BOAT
« on: July 09, 2014, 09:49:55 am »
 with water ballast?
boatmadman
Re: Has anyone made a crane barge
« Reply #1 on: July 09, 2014, 10:53:09 am »
 No reason why it shouldn't work.
You will have to make sure the ballast tanks are completely full and vented of any air otherwise the free surface effect of water in the tanks will introduce instability.
Ian
U-33
  • K-157 Vepr. Akula-11
« Reply #2 on: July 09, 2014, 10:57:00 am »
And baffled to prevent the water sloshing about and causing instability.
« Reply #3 on: July 09, 2014, 10:58:16 am »
Couple of build here on Mayhem if you do a search from the front page!  :-))
boatmadman
« Reply #4 on: July 09, 2014, 11:33:53 am »
Baffles...yes. ..forget those.
However, if the tanks are full there will be no sloshing :-))
U-33
« Reply #5 on: July 09, 2014, 11:56:18 am »
Don't you believe it...there will be sloshing, trust me. Been there, done it, ended up removing a wtc out of a sub and installing baffles.
