Author Topic: Seaport tug motor ?  (Read 7301 times)
rhardy67
Seaport tug motor ?
« on: July 25, 2014, 03:17:09 am »
Can anyone tell me what size stock motor is in the seaport tug , looking for something with a little more power . the stock motor seams a little weak when pushing  , don't want to change motor mount , looking for a bolt on replacement .
1 Traxxas Rustler VXL + HK Aquaholic rc boat and Seaport tug + Traxxas Slash 4x4 platinum + Pro boat Impulse 31 .
StuartL
Re: Seaport tug motor ?
« Reply #1 on: July 25, 2014, 09:08:45 am »
I've torn mine apart now, but I think it's a 380 size...
« Reply #2 on: July 25, 2014, 09:18:37 am »
Defo a 380 size
Anything bigger will need a change of motor mount.
Nordsee
« Reply #3 on: July 25, 2014, 09:22:31 am »
I put a 385 in mine, worked a treat, not so high revving as a 380.
rhardy67
« Reply #4 on: July 25, 2014, 11:03:04 am »
any recantations on how many turn motor , looking for more pushing power . stock motor don't seam strong enough real slow for retrieving .
Nordsee
« Reply #5 on: July 25, 2014, 07:34:30 pm »
The 385 is a 5 pole Motor, more torque less revs.
rhardy67
« Reply #6 on: July 25, 2014, 11:05:22 pm »
I'm running a bushed motor ? read the beginning .
vnkiwi
« Reply #7 on: July 25, 2014, 11:47:56 pm »
Hi fhardy67,
You are running a 380 brushed can motor.
Nordsee is suggestion a 385 - 5-pole brushed can motor as a direct replacement (same dia etc), which has more torque (more grunt) and less revs.
So there you go, you have your answer.
I have done the same swap in one of my boats. (not a seaport), but worked well.
cheers
vnkiwi :-))
rhardy67
« Reply #8 on: July 26, 2014, 12:11:45 am »
Hi fhardy67,
cheers
vnkiwi :-))
OK . sorry about that all i seen was i thought was 4 pole which is bushlles . now i under stand , seen 385 bushed motors with different turns like 18trn .
rhardy67
« Reply #9 on: July 26, 2014, 01:13:46 am »
Would this motor work . 6 to 24 Volt DC 5 Pole Motor Manufactured by Mabuchi # 385S motor has a twelve tooth gear on shaft. 12 Volt operation, 1.09" Diameter X 1.49" Long, Shaft .055" Long X .09 Diameter. I know i'll have to take the gear off . Should also say I'm running 3s 5000Mah traxxas power cell battery .
