Author Topic: Outboard motors...  (Read 4393 times)
U-33
  • K-157 Vepr. Akula-11
Outboard motors...
« on: November 12, 2014, 02:48:01 pm »
Chaps, are model outboard motors still available, does anyone know? I'm looking for 540 sized one, around...1/8th-1/6th scale?
Any ideas, anybody?
Calimero
    • Calimero's RC shed
Re: Outboard motors...
« Reply #2 on: November 12, 2014, 03:21:18 pm »
More on the scale side or more on the performance side ?
I recently got this one from TFL through HobbyKing: http://www.hobbyking.com/hobbyking/store/__22953__Sprint_F3_Tunnel_Hull_Outboard_Motor_Set.html
Quite popular among the 1:5.2 VO crowd in Germany and the Netherlands. It seems the bronze bushing should be changed by a teflon-metal one but appart from this it seems pretty good and very cheap.
They also recently added this one but no reviews on it yet: http://www.hobbyking.com/hobbyking/store/__66147__CNC_Aluminum_Outboard_Style_Boat_Drive_w_2630kv_Motor.html
U-33
« Reply #3 on: November 12, 2014, 04:14:09 pm »
Bob...excellent, well done that man! They will do a treat.
Calimero...a bit too rapid for what I need, but thank you anyway.
Much appreciated, gentlemen...
johno 52-11
  • Model lifeboats built to perform
    • lifeboat Models
« Reply #4 on: November 12, 2014, 04:45:06 pm »
Any use:
http://www.ebay.co.uk/itm/PAIR-OF-Mercury-Outboards-Toy-Boat-Motor-Battery-Operated-old-shop-stock-boxed-/371109217065?pt=UK_ToysGames_RadioControlled_JN&hash=item5667d54329
I got some of these some time ago from a hobbies site for about £5 each. You need to be aware they are a pod type motor that runs of two AA battery's. The one's I got were not very well sealed and they got water in the motor and soon stopped working.
I ended up building my own http://www.lifeboatmodels.co.uk/atlantic.htm http://www.lifeboatmodels.co.uk/atlanticmotors.htm http://www.lifeboatmodels.co.uk/atlanticmotors2.htm http://www.lifeboatmodels.co.uk/atlanticrebuild.htm
The last page is from when I rebuit them with Brushless motors.
johno 52-11
    • lifeboat Models
« Reply #5 on: November 12, 2014, 05:01:54 pm »
found the site I got them from Looks like they are doing 2 versions now http://hobby.uk.com/catalogsearch/result/?q=outboard&x=0&y=0
U-33
« Reply #6 on: November 12, 2014, 06:14:35 pm »
Thanks fellas...I'm now sorted, just awaiting the delivery of the hull.
U-33
« Reply #7 on: November 17, 2014, 02:24:11 pm »
Whilst waiting on the postman, I thought I have a play with the outboards. For what they are, they are surprisingly pokey, so I think I'm on a winner here.
The 'Action Force' stickers will have to come off though, I've done one, looks a whole lot better. On my little fishing dingy I did many moons ago, I converted the outboard to run on a separate battery pack with an Action Electronics mini esc tucked away out of sight, so I think that's what I'll be doing with these.
« Reply #8 on: November 17, 2014, 10:13:09 pm »
Could you post a few measurements?
Son whats to build a Top Gear Toybota and they might fit the bill
U-33
« Reply #9 on: November 17, 2014, 10:34:51 pm »
If you can hang on until tomorrow morning, I'll do that for you E2V...no problem.
U-33
« Reply #10 on: November 18, 2014, 09:55:10 am »
Measurements are:
Maximum height: 125mm
Maximum width: 66mm
Width across the prop exit: 60mm
Hope that helps?
« Reply #11 on: November 18, 2014, 01:16:07 pm »
I think I'll order some and we can give them a go.
Im sure I can find a use for them if the Toybota doesn't pan out
just a thought you could probably fit the esc in the battery compartment on top of the motors
