Author Topic: Wood Veneer strips  (Read 7731 times)
Bill D203
  • not long now!!
Wood Veneer strips
« on: March 23, 2015, 05:47:45 pm »
Can anyone help me find some wood veneer strips? Im looking for some around 12mm wide by 300mm long Any wood will be OK.
Or if you can tell me what decking was fitted on a Huntsman ?
Cheers.
black magic racing
  • when winning is all . it stops being a hobby
FAST is never FAST enough
Black Magic Racing with BMPRS    Telford Model Boat Club
Birkenhead Model Power Boat club Vice Commodore
Car wash !!!
Re: Wood Veneer strips
« Reply #2 on: March 23, 2015, 09:16:12 pm »
Hi Bill try cornwall model boats
ps fitted car with extra airbags [flotation devices]
boatmadman
« Reply #3 on: March 23, 2015, 09:45:35 pm »
I used stripped Ikea wooden blinds for my huntsman deck, nice bit of lime wood!
« Reply #4 on: March 24, 2015, 01:04:47 am »
If you are going to use these for planking, look for a wood with very fine grain, otherwise it will look odd at scale.
I did see a lot of basswood (aka lime/box/linden) strip and blocks in one of the big hobby superstores a while back, in the modelling section. That is very fine grained.
flashtwo
« Reply #5 on: March 24, 2015, 07:38:54 am »
I've used both these companies for my Edwardian Steam launch ( see http://www.modelboatmayhem.co.uk/forum/index.php/topic,37563.25.html )
http://www.woodveneeruk.co.uk/products.php?cat=Samples
http://www.originalmarquetry.co.uk/
As you can see, they can supply a whole range of "samples" of the size and type you need.
You might need to consider the correct glue. I've been using Weston's yacht epoxy, but whatever you use, be aware that some wood substrates (i.e. ply ) can absorb the glue too much and create dry patches with no adhesion; you may have to seal the wood before hand with a thin coating of glue.
Like all new techniques, try a few experiments first.
Ian.
inertia
« Reply #6 on: March 24, 2015, 09:34:45 am »
Cheers.
Bill
There are loads pf photos of Huntsmen on the Fairey Owners Club website. In particular there is a restoration blog by Scott Pett of his H31 "Mirak". https://picasaweb.google.com/116493500049865636778/1968No5Mirak  The majority seem to use teak for decking; there's an interesting remark that the caulking work, if done by a commercial company, would have cost £3000!
Dave M
Captain Povey
« Reply #7 on: March 24, 2015, 10:15:31 am »
Have a look on the Jotika website. Graham
Brian60
« Reply #8 on: March 24, 2015, 11:47:30 am »
You could do worse tha to try this hobby supplier
http://hobby.uk.com/materials/wood.html
Ron Rees
« Reply #9 on: March 24, 2015, 05:47:46 pm »
Buit a lot of Fairey boats, most of the originals from the 60's had teak decks. The 31 inch model,s deck strips would be about 5mm wide but 6mm looks good too.
Try to get hold of a copy of Model Boats July 2013  my article ,Away with the Faireys, shows you a way of doing it.
Real teak is hard to get and poses problems of getting varnish to stick because it is an oily wood. The suggestions already posted have merit and a good fine grain brown coloured wood will do nicely.
Happy boating
« Reply #10 on: March 24, 2015, 05:57:06 pm »
On real faireys the teak would not be varnished.
My Huntress was decked with bare teak.
« Reply #11 on: March 24, 2015, 06:01:52 pm »
On real Faireys the teak would not be varnished.
Quite right, Teak is not normally varnished but weathers to an attractive silvery grey colour. Varnish is for upperworks.
« Reply #12 on: March 24, 2015, 10:01:15 pm »
That would be hobbycraft..... got a couple of big packs of mixed balsa from there for 2.00 a bag last weekend.
« Reply #13 on: March 25, 2015, 12:59:16 am »
Possible source of teak (or other solid woods) is solid wood flooring. You get the packs of factory prepared t&g that is about 500mm - 1m long.
If you can find a company that does flooring and ask them if you can get some of the offcuts from a job. There are always a lot of offcuts from where floor meets skirting board.
The only thing you will need to be wary of is graininess. As hardwoods are getting rarer, they are now processing woods from parts of the tree that are more grainy. I have some fantastically grainy teak, looks great as a floor but not so realistic on a model perhaps.
However, you will then need to prepare the wood yourself. A planer will be needed, and a fine (or modellers) circular/band/fret saw.
