Pages: [1] 2 3   Go Down
Author Topic: MDF or Ply........ Foamex sheet?!  (Read 25221 times)
pcresser
« on: March 25, 2015, 04:53:23 pm »
Hello, whats the best for making the frames of a boat  mdf or ply.
Paul.
Charlie
  • I spend far too much time on Model Boats Mayhem!
    • My Youtube Channel
Re: mdf or ply
« Reply #1 on: March 25, 2015, 04:54:46 pm »
Ply
Re: mdf or ply
« Reply #2 on: March 25, 2015, 05:02:32 pm »
Ply
Re: mdf or ply
« Reply #3 on: March 25, 2015, 05:15:31 pm »
Marine  ply
MDF is like a sponge in a marine environment.
Make sure the ply you buy is WPBP
That's waterproof boilproof.
Give it a couple of coats of varnish or epoxy also
roycv
Re: mdf or ply
« Reply #4 on: March 25, 2015, 05:23:48 pm »
Hi I will join in the choice of ply.  Whenever I make a model boat mainly from wood I only use the best materials.
The reason is how long do you want the model to last?
It is possibly and in my case certainly, that the models will out last you.
I great pity to have them rotting from bits out of site because you are a "cheap skate".
regards Roy
Plastic - RIP
  • Inactive
  • Bobbing Along!
Re: mdf or ply
« Reply #5 on: March 25, 2015, 05:32:50 pm »
Foamex sheet - wateproof, UV-stable, easy to cut, put it together with Polypipe glue.  :-))
Wood is way too much hassle.
inertia
Re: mdf or ply
« Reply #6 on: March 25, 2015, 05:41:46 pm »
MDF is just about OK for a boat stand, as long as you give it several coats of thinned polyurethane varnish to soak into the fibres and set up hard. BTW the dust from cutting or machining or sanding it is apparently carcinogenic, so either wear a decent mask or don't book your holidays too far in advance. Other ways of encouraging fatal diseases are available.  :o
Plastic
Is that Medium Density Foamex or WaterProof + BoilProof Marine Foamex?
DM
Plastic - RIP
  • Inactive
  • Bobbing Along!
Re: mdf or ply
« Reply #7 on: March 25, 2015, 06:25:12 pm »
Plastic
DM
Didn't know there was more than one type. I use the 8'x4' sheets that sign-makers use in 1mm, 3mm & 5mm thicknesses.
sparkey
Re: mdf or ply
« Reply #8 on: March 25, 2015, 07:08:58 pm »
 ok2 Wood every time,use good quality materials and treat the wood with good vanish and paint and the boat will last a life time,besides working with wood is very enjoyable and tactile which I don't get with plastic materials but some of us modellers use anything to hand and have great results who am I to judge,there again I am as old as the ark and used to my old ways,Ray. ;)
html
  • Gipping Valley Model Boat Club
Re: mdf or ply
« Reply #9 on: March 25, 2015, 09:32:32 pm »
Always waterproof ply, less prone to twisting and warping. Also less precautions required when cutting a lot of it, can also be lighter than MDF. I do not think they use MDF on full size boat frames, why use it on a model?
I do not suffer insanity, I quite like it!
david48
Re: mdf or ply
« Reply #10 on: March 25, 2015, 11:14:19 pm »
I had a quarter sheet of 10 mm MDF and it was in the shed and it got slightly damp at one end it has swelled to over 15mm thick ,so by now you will have the message that MDF is no good .
Use good quality modeling ply then when it is cut it will have no holes or cracks in the laminate build up . Sorry I can not give  links to suppliers but someone on here will put you in the right direction
David
inertia
Re: mdf or ply
« Reply #11 on: March 25, 2015, 11:20:55 pm »
These guys have never fallen short of excellent in either quality or service http://www.slecuk.com/balsa-wood/Birch-Plywood.html
DM
Re: mdf or ply
« Reply #12 on: March 26, 2015, 01:58:41 am »
Plastic,
What thickness do you use for frames? Is 5mm sufficient?
I am thinking of both rigidity and glueing area here.
As this is an alternative construction material, and possible different methods of construction, could you do a build thread please?
Or some other thread at least showing some models or the model making?
I am sure some of the member would be interested to see this. :-))
pcresser
Re: mdf or ply
« Reply #13 on: March 26, 2015, 07:05:37 am »
Hi everyone, thanks for all the replies and advice.
Many thanks,
Paul.
Plastic - RIP
  • Inactive
  • Bobbing Along!
Re: mdf or ply
« Reply #14 on: March 26, 2015, 07:27:36 am »
Plastic,
Wherever extra strength or a larger gluing area is needed I just slap another layer on. The glue dries in seconds so you can build incredibly quickly. You can change your mind and just chop material away or glue some back in no time. I use more glue or waterproof PVA to seal any exposed foam edges to make a paintable surface.
This board cuts easily with a Stanley knife or with scissors.
I've attached a pic of a 1/200 Titanic I did a couple of years ago.
Arrow5
Re: mdf or ply
« Reply #15 on: March 26, 2015, 08:56:00 am »
Tell us more Plastic. I`m interested in the material and can see it as a useful  addition to keep our costs down.  Bonus would include less prepping for paint , less sanding, smooth surface etc etc.
..well can you land on this?
Plastic - RIP
  • Inactive
  • Bobbing Along!
Re: mdf or ply
« Reply #16 on: March 26, 2015, 09:36:39 am »
It's a great material - I last paid £30 for 8'x4' 3mm sheet. It has no grain, it's slightly flexible and plumber's PVC glue sticks it together. You can also use the glue as a filler for small gaps.
It weighs nothing - the whole Titanic hull was less than 1kg (it is double skinned & double bottomed to be very rigid and have lots of watertight compartments. I've attached another earlier pic showing the structure.
*This all came about when I was given the 1/200 Taschen card model Titanic (it comes as a book as a waterline model to build) and I wondered how difficult it would be to build it into a working model.
The model essentially forms a simple 2d pattern for me to replicate in Foamex (deducting the material thicknesses where appropriate) and I had to to invent the below waterline part of the hull using traditional techniques.
I was going to use Plasticard for the model but it worked out too expensive so this material was next on the list. I totally recommend it.
Arrow5
Re: mdf or ply
« Reply #17 on: March 26, 2015, 10:02:14 am »
Thanks Plastic.   Modern methods and materials  not to say electronics and motors are slower to be adopted in the model boat world than in other forms of modelling.  Any more of your builds to show us ?   Titanic looks good. Scaling-up card models are as good if not better than plans IMO.
Re: mdf or ply
« Reply #18 on: March 26, 2015, 10:55:34 am »
... and have lots of watertight compartments...
Not like the original then  :-X
grasshopper
    • A1 Hobbies Ltd.
Re: mdf or ply
« Reply #19 on: March 26, 2015, 02:55:20 pm »
Isn't foam board a preferred material for our friend Krishna to make the proliferation of boats that he does?
Re: MDF or Ply........ Foamex sheet?
« Reply #20 on: March 26, 2015, 03:02:30 pm »
Topic renamed!   ok2
U-33
  • K-157 Vepr. Akula-11
« Reply #21 on: March 26, 2015, 03:07:51 pm »
Isn't there a little kit of a Fairey Swordsman available made from Foamex? I'm sure I've seen one somewhere...on eBay, I think? About £30ish.
NoNuFink
« Reply #22 on: March 26, 2015, 04:15:47 pm »
@plastic
Have you got a link to a local source of foamex? (I'm in the same part of the world as you)
It's not something I've come across before.
NNF
Arrow5
« Reply #23 on: March 26, 2015, 04:34:21 pm »
I I think Krishna uses a paper and foam type of "foamboard" .   We have to be careful about  terminology here.
« Reply #24 on: March 26, 2015, 04:39:01 pm »
Yeah
Speedline methinks
Pages: [1] 2 3   Go Up
Page created in 0.023 seconds with 19 queries.
