Author Topic: Krick Victoria with an electric motor -- sensible or not?  (Read 6904 times)
Stuart
« on: April 11, 2015, 06:51:23 pm »
I have a new Krick Victoria kit. The steam plant does not meet current safety regs, so I am advised as only hard soldered, plus the cabin does not appeal, ......................
My Borkum kit from Germany arrived damaged so has been sent back for refund.
So it seems an electric powered open launch will be the best solution for a first kit build, as a replacement steam plant at several hundred pounds is not on.
Any other suggestions/ possibilities / comments would be appreciated.
One of the moderators has suggested a build thread so just wondered if it would be of interest to forum members?
Thank you.
Stuart
Seacommander
Re: Krick Victoria with an electric motor -- sensible or not?
« Reply #1 on: April 11, 2015, 07:23:25 pm »
I've the Alexander, the smaller kit on Electric.
I did not make this, it came ready to sale, with an amount of other boats in a job lot.
Me being me, I had to try it, it's great!! Sails well and very convenient, the plan was to let it go....... still got it
Have a go
Mark
Jerry C
« Reply #2 on: April 12, 2015, 07:32:04 am »
You don't say where you live. If you live in the UK then there are no "safety regs" on a small steam plant like hers. There may be some club regs which you have to abide by if you are a member but if you're solo steam away. You mentioned "hard soldered", if you mean silver soldered then the boiler is ok. If soft soldered then it would not be safe.
An electric powered steam launch, Nooooooooooooo!
That said, I'm sure it would be pretty easy to do and the real regs are:- if it's your boat do whatever you want.
Jerry.
Stuart
« Reply #3 on: April 12, 2015, 08:12:29 am »
Home is in the Taw valley.
The boiler is not silver soldered and several members have now sent a pm saying gas, brass, not silver soldered is bad news for which I am grateful.
Your advice on electric power is appreciated and accepted, I  did have my doubts.
All considered, it can stay in the box until I can find it a good home.
Thank you
Stuart
U-33
  • K-157 Vepr. Akula-11
« Reply #4 on: April 12, 2015, 10:48:52 am »
Have a word with my mate Ian  (IanPAL on here) he's building a steam launch with an electric powered twin cylinder engine in it, and all the radio tucked away inside the boiler tube.
BTW, the Krick steam engine and boiler are perfectly safe to use as they are...Graham Sheppard (Mr Hunter Systems) and I built one each, and we never had any problems sailing them anywhere.
Stuart
« Reply #5 on: April 12, 2015, 11:03:15 am »
Hello Rich.
Thanks for input - that is an interesting idea.
Stuart
Stuart
« Reply #6 on: April 12, 2015, 11:05:53 am »
Following the advice from a moderator, and to stop members complaining about my swop advert as having less than 25 posts, I shall wait until I have met the posting requirements before making available to members.
I misunderstood the 25 post rule as being for SALES only, so my mistake.
Stuart
« Reply #7 on: April 12, 2015, 11:07:40 am »
Picture of steam plant in question  --   just assembled.
If not safe to use, then it will make a nice display unit
Stuart
« Reply #8 on: April 12, 2015, 07:52:08 pm »
I understand that my motives to swop were really a sales advert in disguise. I understand that some complaints were made. It does not sit well with me that there is an under current on the forum when I clearly stated swop only in my advert.
Enough said.
Brian60
« Reply #9 on: April 13, 2015, 09:09:12 am »
Stuart you may be coming up against resistance as you are still showing as a 'Guest' poster.
 As to your engine, in post number 8 looking at that set up, if you wanted to go electric it seems fairly easy to accomplish. A LIPO or similar battery pack would fit up inside the boiler and a small motor at the bottom. Connect the motor to the actual steam piston part of the drive with a small shaft direct to the end of the crankshaft.
tobyker
« Reply #10 on: April 13, 2015, 10:01:32 pm »
If you do drive the steam engine with an electric motor (and why not?), do arrange to lubricate the pistons etc from time to time.
« Reply #11 on: April 14, 2015, 10:36:19 am »
It is not know at this stage, whether Stuart has left the club or not.
Stan
« Reply #12 on: April 15, 2015, 01:57:32 pm »
Hi tugkenny  just received e/mail Stuart has left the forum
Stan.
« Reply #13 on: April 15, 2015, 08:15:50 pm »
Thanks Stan
Stan
« Reply #14 on: April 23, 2015, 10:40:19 pm »
Hi Tug Kenny I have been asked by Stuart who is no longer a member of this forum for all pictures to be removed from this section.
Stan
« Reply #15 on: April 24, 2015, 09:59:18 am »
That would be Martin's prerogative as it's his forum, Stan
cheers
« Reply #16 on: April 24, 2015, 10:01:13 am »
You could just hide the thread from public view
Page created in 0.027 seconds with 19 queries.
