Author Topic: drawing a keel from plan  (Read 3170 times)
surabaya
« on: May 19, 2015, 06:56:13 am »
Hi all. Probably a simple answer, but can someone point me to the right place.
I want to make a tug from a plan but it does not show the keel. Do I just draw the outline and make a guess at how deep or thick to make it ?
How do you guys start off making the keel?
Thanks all.
Jerry C
Re: drawing a keel from plan
« Reply #1 on: May 19, 2015, 08:37:15 am »
Can you give us more info on the tug in question. More modern tugs don't have the traditional "keel", being built up as a kind of monocoque construction. If the plans don't show a keel, does it actually have one?
Jerry.
surabaya
« Reply #2 on: May 19, 2015, 10:40:46 am »
Hi, I will check when I get home as I'm on the road.
As I remember it shows the plan, side view and contours from the front. I want to use plank on frame so I thought I would need to make a keel to hold frames in place.
But I will put name of plan later, maybe someone has made it.
thx
« Reply #3 on: May 19, 2015, 12:37:47 pm »
when ever I have been taking a keel from a drawing that actually doesn't show model making construction lines I have allowed at least 20 - 25mm all around where the base line of the planking meets the "keel" and depending on size of model use either 4 or 6mm thick timber.this gives a good strong keel that usually won't twist. neil.
surabaya
« Reply #4 on: May 19, 2015, 05:27:11 pm »
Hi, all. Home now.
The tug plan is the Archer and after a search I found that there is a build thread on here of same, so I am going to study that first and then perhaps ask some dumb questions :embarrassed:
« Reply #5 on: May 19, 2015, 07:44:51 pm »
hi there Surabaya
Have a look in the master build section: under the Cervia tug build and that will give you a better description of how to do your framing, of your keel etc.
Basically, it is a similar tug to the Archer.  The Archer being a slightly smaller tug and the other difference is the Archer is a direct drive with a 555 motor; and the Cervia uses a belt drive gearbox with a 540 motor inside.
By the way, there are no dumb questions which are asked - the dumb questions are the ones that aren't asked :-) so please ask away.  That is what we are on forum to help one another.
aye
surabaya
« Reply #6 on: May 21, 2015, 04:15:06 pm »
Hi, thanks all, I think I have it now.
If it has a real keel, I  just measure up and draw appropriate line to correct depth,,
 but if it does not have a "keel" I can just draw a line 20 or so mm inside outline and use that to build from, of course allowing for the thickness of the planking,
Thx, bluebird, The Cervia build really helped.
Page created in 0.04 seconds with 17 queries.
