Author Topic: How do drill glass  (Read 5712 times)
Klunk
How do drill glass
« on: May 28, 2015, 06:06:43 pm »
As in the title. I need to drill a round hole in a large glass bottle. How do I do this apart from carefully! Special drill bits etc
full time penguin
Howard
Re: How do drill glass
« Reply #1 on: May 28, 2015, 06:18:44 pm »
You will need whats called a spear head drill and If am right a ring of putty and some  white sprit.
                Regards Howard.
« Reply #2 on: May 28, 2015, 06:24:12 pm »
And go slow.
Blue tack or putty for the cofferdam.
david48
« Reply #3 on: May 28, 2015, 06:24:30 pm »
What size hole .If I remember dermal used to do a glass engraving wheel .have a look on  Toolstation I have just bought a drill for ceramic /hard porcelain it worked perfect  .It says it will drill glass ,not tried that .David
gingyer
« Reply #4 on: May 28, 2015, 06:31:53 pm »
Get someone else to do it
They take the blame when it goes wrong  O0 O0
Klunk
« Reply #5 on: May 28, 2015, 06:37:34 pm »
It's a 14mm hole
full time penguin
sparkey
« Reply #6 on: May 28, 2015, 06:46:34 pm »
 :-)) You can get drill bits for glass from Screwfix I know I get some to drill mirror,works O.K. just don't use too much pressure,Ray. :-)) :-)) :-))
« Reply #7 on: May 28, 2015, 07:41:45 pm »
Is it a flat bottle, like a gin bottle or a round bottle like a wine bottle?
GAZOU
« Reply #8 on: May 28, 2015, 08:15:12 pm »
To remove the cork is a good thing
Brian60
« Reply #9 on: May 28, 2015, 08:28:35 pm »
Also fill it with water and cork the end. This will damp out any vibrations.
Klunk
« Reply #10 on: May 28, 2015, 08:31:53 pm »
Large round bottle. Ie teachers whiskey pub size
full time penguin
« Reply #11 on: May 28, 2015, 08:52:42 pm »
You do know it will drill an elipse in the glass.
Klunk
« Reply #12 on: May 28, 2015, 09:18:57 pm »
Yep that's not a problem. It's having another tube attached to it for an experiment.
full time penguin
J.beazley
  • The building never ends
« Reply #13 on: May 28, 2015, 10:11:58 pm »
It's not going to be easy that's for sure.
I've drilled many glass fish tanks of various thickness glass upto 28mm thick you just have to take it slowly and use plenty of water as you drill to reduce heat build up which will cause cracks or chips.
Helps having a decent drill with adjustable setting of rpm.
Jay
Umi_Ryuzuki
    • Models and Miniatures
« Reply #14 on: May 28, 2015, 11:10:58 pm »
Could you use a stopper with holes in it like a lab?
thething84
« Reply #15 on: May 29, 2015, 01:24:26 am »
I drill two holes in a fish tank using a glass  diamond coated drill. Cut bueatifully. Apply no pressure to the drill just let it do the work itself. I made up a little piece of wood to hold the drill in place till its started cutting its groove. As said create a dam around it and keep a flow of water on it.
This is what i used.
http://www.ebay.co.uk/itm/DIAMOND-HOLE-SAW-4mm-125mm-Tile-Ceramic-Porcelain-Glass-Marble-Drill-Bit-Cutter-/201159703385?pt=LH_DefaultDomain_3&var=500326903373&hash=item2ed60d7b59
James
If it ain't broke! Fix it anyway!
Page created in 0.423 seconds with 18 queries.
