Author Topic: HobbyKing - Aquaholic!  (Read 13670 times)
Re: HobbyKing - Aquaholic!
« Reply #25 on: September 02, 2015, 10:58:27 pm »
I ALWAYS do is pressure test the water cooling piping, using Mk I pressure pump..... me lungs!
Damn it! It leaks!
The pickup pipe is held in place with a stainless steel Allen screw... screwed into plastic.... hmmm!
OK, back to plan B -  'drilling the plastic and pushing the pipe straight through.'
A another 2 hour search of my ' save those bit' boxes but no 5mm tube, ordered a bit off fleabay.
« Reply #26 on: September 02, 2015, 11:07:05 pm »
The hatch is quite thick moulding and I can't quite work out if it's once piece foam mould thing or something else.... or if it even floats!
( I lost a hatch once so always fit a lanyard or flotation. )
I just need to fling it in the bath.......  but it not that time of year, yet!
« Reply #27 on: September 02, 2015, 11:13:04 pm »
Talking of flotation....
And then some more!
JimG
« Reply #28 on: September 03, 2015, 10:30:31 am »
Back outside, the hull has two drain points.
Hi Martin,
I think that you will find that the upper one is not a drain but is intended for the Rx aerial, there will be a hole through it allowing the wire to fit. (only for receivers with longer aerial wires.) This gets the aerial as high as possible.
Jim
Dundee Model Boat club
Page created in 0.162 seconds with 17 queries.
