Author Topic: New Shannon class lifeboat from Speedline Models  (Read 14209 times)
Flundle (Speedline Models)
« on: March 03, 2016, 04:43:56 pm »
For a company as small as Speedline Models, choosing to bring out a Major kit is a big decision.
 We asked ourselves 'Is it going to be worth it in this ever changing world where ready- to-run models are gaining in popularity and the skills to build complex kits are become more scarce by the day?
[/size]If we thought the answer was no, you would not be reading this so obviously we think the answer is yes so long as :
[/size]·         1. The kit is outstanding and offers some really innovative features.
[/size]·        2.The kit suits the markets needs in terms of size.
[/size]·         3.The kit offers great value for money.
[/size]·         The kit  is buildable by people who have never built such a kit before and perhaps don’t believe they can successfully tackle such a project.
[/size]So let us offer you the new Shannon Class lifeboat kits.
[/size]'Kits' because it's available in 1/16th and 1/12th scales.
[/size]Speedline lifeboat kits are well known for their amazing details and quality where laser-cut components and etched metal sheet  is combined to make parts with outstanding detail.
 The Shannon kit has none of this technique at all and instead makes extensive use of cast resin components. Not just for detail (though that as well of course) but for major components such as the bridge, the mast and the interior.
[/size]Etched brass is used for some items where functionality or strength demands it.
 Items such as the trim tabs which don’t just work but are automatically controlled in response to the pitch of the boat, keeping the intakes for the jet drives in the water.
[/size]The wheelhouse is moulded onto the deck, a radical solution to the problem of how to disguise the joint  between the deck and the wheelhouse when on the real thing of course there isn't one.
 It brings enormous advantages in other areas too.
[/size]The hull moulding has a 25mm wide flange around the lip of the inside edge to ensure the deck sits at precisely the correct position and is located perfectly (in the manner of a chocolate box lid).
[/size]Included are the interior bulkheads between each room below deck, providing not just additional strength but they have the access hatchways cut in them too so should you want to, you can build a complete, below the deck interior which can easily be shown simply by lifting the deck off.  (We may at some future date make the parts available).
[/size]The deck and wheelhouse carry the appropriate non-slip areas, and the locations for all the components that fit onto or into them are moulded too.
[/size]The window locations are very accurately moulded to allow the direct glazed windows to fit precisely. Special graphics on the inside and outside of each window give perfect results.
[/size]All previous RNLI lifeboats have extruded section rubber fendering glued the outside edges of the hull.
 The Shannon however is very different. It has moulded sections of rubber fendering glued in place on both deck and hull sides giving that very distinctive appearance.
[/size]The fendering is narrower at the bow then it is at the stern and has a distinctly tapered section at the point where the deck begins to rise towards the bow and ending at a point approximately level with the front of the wheelhouse.
 We have moulded the fendering in two sections so that it just drops into place and is glued to the deck providing a nice waterproof seal and an invisible joint line.
 Apart from this changing section, the fendering also has a distinct light mottled texture and this is very effectively moulded in too.
[/size]All the fittings including windscreen wipers , winch, bollards, fairleads, working lights, radar, sirens, loudspeaker and sea catch are made from finecast resin and simply require painting and fitting.
[/size]The mast assembly is fully detailed and has been made in such a way as to enable it to be removed in one piece for transportation. Electrical connections are built in so no need to worry about the electrical wiring.
[/size]A huge feature of the Shannon is of course the jet drives.
 The real things are made by Hamilton in New Zealand and are very distinctive.
 Because no commercial drives are available which either fit properly or look right, we have designed our own.
 They have a very scale like appearance, have operating reversing buckets and steering which works in the same manner as the full size, no push me pull me rods or wires are used thereby keeping the scale like appearance at the transom.
 A pair, with matched brushless out-runner motors are provided in each kit.
[/size]Decals are included for 13-06. Decals for all other Shannon Class boats are available by special order.
[/size]The kits will be sold complete and no parts of the kit will be available individually except of course as replacement parts.
[/size]Each kit is numbered and carries an engraved plaque in the hull.
[/size]Kits will be available in the late summer (July is target date) and cost £795 for the 1/16th version and £895 for the 1/12 version.
[/size]Orders will be dealt in strict rotation (many are already 'booked' by potential customers on model Boat Mayhem and they will be supplied with first).
[/size]To everyone on Model Boat Mayhem who previously said they would like one will be given a 10% discount off the price if they order and pay 50% for one between now and the end of March. By way of a thank you for your support.
[/size]Anyone ordering one on the same basis during the two days of the Ellesmere show will be given the same 10% discount.
[/size]As a special surprise for Model Boat Mayhem members I would like to offer a complete kit to Martin for him to build on line. Warts n' all of course Martin.  What do you say?[/size]
timbo
Re: New Shannon class lifeboat from Speedline Models
« Reply #1 on: March 03, 2016, 05:55:51 pm »
Having purchased a seven class last summer and been very pleased with the quality of the kit I have no doubt that this kit with be well worth the money, looking forward to seeing it at ellesmere show.
Atlantic Mouldings
« Reply #2 on: March 03, 2016, 05:59:05 pm »
Looking forward to the Summer Adrian it will be well worth the wait  :-)) :-)) .
« Reply #3 on: March 03, 2016, 06:11:57 pm »
Thanks Alan
I tried to post some piccies but messed it up. Copying  from a word doc carries all XML across too so message is a mess. Hope Martin can do some editing??
I wonder if he'll accept the offer?
gribeauval
« Reply #4 on: March 03, 2016, 07:18:52 pm »
Thanks Alan
If Martin does't accept, then I will build it!!    {-) {-) {-)
True Lifeboat Nutter!!
slinger
« Reply #5 on: March 03, 2016, 07:40:58 pm »
Looking forward to seeing it at the Ellesmere show, have to check the bank balance though.  Weather forecast seems to be fair for the two days, cold but dry :-))
Graham
« Reply #6 on: March 03, 2016, 10:30:27 pm »
At the show we will be showing the masters for the hulls, the ress will be developed between now and then.
They will a have bronze impeller and stator and brass/bronze steering bevel gears. They should be pretty well bullet proof.  The real thing has seven bars in a protective grille across the water intake and ours is fitted with 80 thou hard etched brass replicas so that should keep the Carp out!
This is a tight schedule and without this talented and very busy team it would not be possible.
After the Shannon, the next project will be to do a new 1/12 Trent Class using the same philosophy and again the times scales will be as tight as possible.
We have an addative layer 3D printer now but we are getting an SLA printer in April which will help enormously. It also opens up all sorts of fine scale opportunities.
For example, by nipping down to the nearest lifeboat station and getting kitted out in RNLI gear you can be laser scanned and a scale model of you can be on the bridge of your Shannon in no time.
See you Saturday!
The drives will be supplied as complete kits that only require assembling.
Both kits are identical except of course for there size so the build of the 1/12 will be photographed for step by step instructions and videos. Instructions will be supplied on DVD.
« Reply #7 on: March 03, 2016, 10:34:52 pm »
Sorry, messed this post up, bits missing. I appears using a pad and scrolling is rubbish.
Hope to see you Saturday.
irishcarguy
« Reply #8 on: March 08, 2016, 08:44:17 pm »
.I have a suggestion Adrian, if Martin does not accept your offer of a Shannon kit to do a build for the forum may I suggest Jim's friend Neil. He has scratch built several lifeboats on the Forum & they were brilliant builds, mistakes & all. Mike would do a great job of it too but he has a build already under way on the forum ( Great build Mike ) Mick B.
Mick B.
« Reply #9 on: March 08, 2016, 08:50:08 pm »
If Martin says no I have someone else in mind thanks.
irishcarguy
« Reply #10 on: March 08, 2016, 09:32:00 pm »
Good for you Adrian, it does not matter who it is so long as they make a good (great) job & do it justice.   We may meet this year as my wife & I plan to visit some friends in the U/K Mick B.
Mick B.
BFSMP
« Reply #11 on: March 08, 2016, 10:18:07 pm »
Will you be heading up to the north west by any chance, Mick.
I know Neil would love to meet you both  and tell you all about his daughters' success's.
Jim.
irishcarguy
« Reply #12 on: March 09, 2016, 07:21:24 am »
We sure will Jim as you know I lived in U/K & also served 9 years in the RAF. (MT Fitter) I pretty much know my way around having been in Bridgenorth, Weaton Lancs, Locking near Weston Supermare, Felixstowe & the Port of London including Tilbury Docks (shipping vehicles overseas.) & 2 years in Cyprus, I enjoyed most of it except a stint in Aden. The best mates I have ever had were in the RAF. Hope to meet some of you soon & then I can put faces to the names. I also hope to settle some outstanding business issues, as I have done a large trade with U/K on vintage Automobile parts (now winding down,too old ) I would like to visit the model boat shops where I have spent much money too. Mick B.
Mick B.
Delboy1958
« Reply #13 on: March 09, 2016, 10:45:58 am »
Hi Adrian
Any pictures ?
« Reply #14 on: March 09, 2016, 12:34:24 pm »
I wish I could put some up but cannot figure it out %% . I could (I think) put up a file on Dropbox though and give everyone access to it?  I'll try it and let you know.
Charlie
    • My Youtube Channel
« Reply #15 on: March 09, 2016, 01:23:55 pm »
Hi Adrian,
You need to make sure that the file size of each photo is under the permitted 300KB limit, otherwise you won't be able to upload them.
Charlie
« Reply #16 on: March 09, 2016, 03:08:22 pm »
Thanks.
I guess I do that on Photoshop? What do I have to do with Photobucket?
Charlie
« Reply #17 on: March 09, 2016, 07:38:25 pm »
I've never used Photoshop, but you may be able to use it to resize. If you have a Macbook, you just open the photo, click on 'Tools' then 'Adjust Size'. A PC may have an application you can use, or if not, use a free online photo resizer website like this: www.picresize.com
Once you have saved the resized photos on your PC/Mac, you can upload directly onto Mayhem, without any need for a Photobucket Account.
Charlie
« Reply #18 on: March 10, 2016, 01:38:49 pm »
Right Charlie, many thanks.
I'll give it a go.
Tim_M
« Reply #19 on: March 10, 2016, 07:20:40 pm »
On a Windows PC, open the picture in 'Paint'.
Up on the top left there's a button that says 'resize'.
Hit that and select the percentage you want to get the file size right. (I use 15% for pictures from a 16Mp camera).
Save the file and you're done. Very very simple.
It's knowing what I don't know that makes me cleverer than I am :-)
Page created in 0.072 seconds with 17 queries.
