Pages: [1] 2 3 4 5 6 7 8 9   Go Down
Author Topic: New fishing boat  (Read 74966 times)
Stan
New fishing boat
« on: August 01, 2016, 07:03:56 pm »
I have only built one fishing boat during my years of building models. But I have decide to build a second one. I have had this kit some 20 years and the boss keeps asking when are you to finish it so here goes.
Stan
tugboyben
  • Kirkleesmodelboatclub
  • HIGHNOON TUG BOAT
Re: New fishing boat
« Reply #1 on: August 01, 2016, 07:55:50 pm »
Hi Stan
will make a Very nice model  look forward to seeing the build  :-))
 I plan to build a fishing boat over the winter
Jason
« Reply #2 on: August 01, 2016, 07:58:36 pm »
Yup, settling down with a cuppa and some biccies for this  build log Stan.
« Reply #3 on: August 01, 2016, 10:35:47 pm »
Well Stan, I won't be left behind either - patiently awaiting your updates. 8)
barriew
« Reply #4 on: August 05, 2016, 06:48:56 am »
Stan
A note of caution. I have recently completed the Marie Morgane by the same company. After its first outing it was left on the shelf for a few weeks and when I next came to run it the prop shaft had rusted and was seized solid. It would appear that it was not made from stainless steel!
I have replaced it and everything appears to be OK now.
Barrie
Stan
« Reply #5 on: August 05, 2016, 07:37:46 am »
Hi Barrie already binned the internal shaft full of rust.Next problem finding a motor that will fit.May go for a very small brushless.
Stan.
Stan
« Reply #6 on: August 05, 2016, 09:32:18 pm »
The Elco build is almost complete now except for a few odd bits. So today made start on the fishing boat and I have to say with build book translated it still made know sense on construction. So its all down to my skills to build this model. just two pictures to start with.
Stan. {:-{ {:-{ {:-{ {:-{ {:-{ {:-{ {:build book. :-)) :-)) :-)) :-)) :-))just get on with it
« Reply #7 on: August 06, 2016, 08:53:35 pm »
Thats the wrong base board for plank on frame Stan, thats the one you use for Bread and butter! Seriously though progress looks good and I am sure you will do a great job despite the kit originated pitfalls.
Stan
« Reply #8 on: August 08, 2016, 03:24:19 pm »
Just done a little more today some of the timber is not very good may have replace some with light ply. The cabin will built from plastic card and the timber decks will be covered in plastic card also. Motor installation will be a little tight also.
Stan .
« Reply #9 on: August 08, 2016, 10:34:21 pm »
Hi Stan, looks like this is going to be quite a sturdy little boat - will you be adding the type of deck clutter you gave to the Lobster boat?
Stan
« Reply #10 on: August 08, 2016, 10:55:06 pm »
I have a garage set at 1/24 scale ready for this model plus the usual lights and may be a pump to simulate water cooling.
Stan.
« Reply #11 on: August 09, 2016, 08:10:18 pm »
Crikey, thats where all the clamps went! I can see it was trying to fight you.
Stan
« Reply #12 on: August 30, 2016, 06:07:33 pm »
HI all back in the real world again. Work started on this project again more pictures to follow.
Stan.
Stan
« Reply #13 on: September 10, 2016, 08:39:04 pm »
Hi all now back in the garage managed to plank the hull and glass fibre inside. Motor fitted and rudder  plus small pump and sound system just a few pictures enjoy
Stan. :-)) :-)) :-)) :-)) :-)) :-)) :-))
« Reply #14 on: September 11, 2016, 06:18:39 pm »
Excellent progress considering your recent efforts with shows etc. That pump is quite a good size isn't it.
Stan
« Reply #15 on: September 12, 2016, 11:49:56 am »
Yes I bought this very small pump many years ago at a model show its been sat on the shelf for years. It just goes prove that you may buy something and keep it for years but some day it will come in handy.
Stan.
Stan
« Reply #16 on: September 17, 2016, 08:06:55 pm »
Made the most of this dry weather glue dries a treat. Rudder linkage now finished basic cabin construction almost finished. Hope to have hull in primer by the end of the month.
Stan.
tugboyben
  • HIGHNOON TUG BOAT
« Reply #17 on: September 17, 2016, 08:13:31 pm »
Looking good Stan  :-))
Ill be down the pond in the morning to take a look at that pump
Jason
nivapilot
  • re-invented rc boater
« Reply #18 on: September 18, 2016, 07:20:12 am »
Looking good Stan,  :-)) , hope the weather holds off for the painting...... ;)
Stan
« Reply #19 on: September 24, 2016, 05:17:36 pm »
I am having a break from working with wood so I have started to fit out the model. Some pictures showing state of construction others showing battery and various items to make it go.
Stan
eddiesolo
« Reply #20 on: September 24, 2016, 06:14:07 pm »
Lovely work Stan, what sound system are you using?
Si:)
« Reply #21 on: September 25, 2016, 08:56:03 pm »
That is a well laid out engine room Stan!
Stan
« Reply #22 on: October 06, 2016, 05:11:33 pm »
HI all managed to do a little more over last week. I have scrapped the wood material for rear derrick and made it from box section plastic. Various items have been modified or built again using plastic sheet the lights on the derrick are from Calder Craft. I hope to  have most of the construction done by the end of this month picking up some items at Blackpool. Final pictures show the very thin copper wire I now use to connect all my lights. Sorry about the clamps in the pictures
Stan.
Kirklees Model Boat Club
barriew
« Reply #23 on: October 06, 2016, 05:48:23 pm »
Stan
Is that wire insulated?
Barrie
Stan
« Reply #24 on: October 06, 2016, 07:48:20 pm »
Hi Barriew yes it is. I normally cut a piece say 20 foot long double it over fit to my hand drill and twist into a nice rope. This can then cut  to size ends cleaned soldered to your L E D. Finally test all is ok with your L E D tester no need to worry about positive  and negative at this stage. This wire can be bought from Component Shop all my models are wired using this cable when painted it almost vanishes hope this helps.
Stan.
Pages: [1] 2 3 4 5 6 7 8 9   Go Up
Page created in 0.722 seconds with 18 queries.
