Pages: 1 2 3 4 5 6 [7] 8 9 10   Go Down
Author Topic: RAF HSL whaleback in 1/16th  (Read 59572 times)
MartinC
Re: RAF HSL whaleback in 1/16th
« Reply #150 on: September 02, 2021, 09:22:31 pm »
Amazing work
Martin
tghsmith
« Reply #151 on: September 03, 2021, 01:25:11 pm »
gave it some color... now back down the rabbit hole of details...
tghsmith
« Reply #152 on: September 09, 2021, 09:54:25 pm »
made the stern fairleads today, the bow fairlead is next..
tghsmith
« Reply #153 on: September 14, 2021, 08:20:19 pm »
the other end brass was started today, kind of a hard fitting to plan out, not many photos show it well, there most likely was more than one type.. but it will fit on a postage stamp, best guess, I think it will work,, still need to detail it a bit more..
tghsmith
« Reply #154 on: September 18, 2021, 08:38:49 pm »
did some work on the little unimat lathe, staff bases and light lenses, started roughing out the the side light brass bases, most of the final purchases have arrived, radio,sound system, LEDs and R/C switches..
tghsmith
« Reply #155 on: September 21, 2021, 07:09:54 pm »
still have to fit the lenses a little better, but the first test with the LEDS,, camera doesn't taking their photo, but they look nice in person, now to make the stern and forward white light staff.. have a bigger LED to light up the searchlight..
tghsmith
« Reply #156 on: September 22, 2021, 07:41:33 pm »
stern nav light done today...
tghsmith
« Reply #157 on: September 23, 2021, 09:59:22 pm »
forward light today,, pesky little "xxxxx" this was the second attempt... still needs a bit of file work and clean-up
tghsmith
« Reply #158 on: September 27, 2021, 09:12:22 pm »
the light stick is pretty much done..
MartinC
« Reply #159 on: September 27, 2021, 09:15:21 pm »
Lovely work, great attention to detail.
tghsmith
« Reply #160 on: October 06, 2021, 05:05:08 pm »
the 3 ESC's switches will start-up and shut-down the model, wanted to get to them with the cabin in place, added a seat for the mech/snipe in the engine room.. built a speaker pod/box and a easy removable mount for it..
tghsmith
« Reply #161 on: October 09, 2021, 04:36:41 pm »
more of mounting the electronics, started the coxswain cabin ..
tghsmith
« Reply #162 on: October 15, 2021, 08:45:53 pm »
main wiring and electronics sorted, did a test tank "thrust" test, she should run well.. nav lights all fitted out, started test fitting parts..
Nordlys
« Reply #163 on: October 16, 2021, 07:07:17 pm »
I'm following your steady progress eagerly! Just need more photos mate! It's too good for one a day!
N
tghsmith
« Reply #164 on: October 16, 2021, 08:11:06 pm »
here's a couple more... can't wait to start putting it all together..
Nordlys
« Reply #165 on: October 17, 2021, 07:51:06 am »
Is that the battery in the forward compartment, what Size are you going with?
Looks very compact in that compartment even with your 1 /16th size. Mine is 1/24th and thats where I've put my battery, Nimh though 8.4v.
Can't wait to see it all together!
Thanks.
N.
tghsmith
« Reply #166 on: October 17, 2021, 01:51:14 pm »
that's the battery for the sound system.. look back one page, the 3 main batteries are located below the ESC's.. 5200 mah ...
Nordlys
« Reply #167 on: October 17, 2021, 04:59:14 pm »
Yes of course! I didn't have room enough to locate them where you have. In fact my model sits rather low at the stern end anyway.
N.
tghsmith
« Reply #168 on: October 17, 2021, 06:05:54 pm »
having built one in 1/24th way back in the nicad era I can understand about the weight issues, after the first test run I spent a great deal of time  with a dremel removing all uneeded weight,, its nice to have the extra displacement in 1/16th..
tghsmith
« Reply #169 on: October 19, 2021, 09:48:50 pm »
hatches, hinges, flanges, and hopefully the last coat of primer..
tghsmith
« Reply #170 on: October 21, 2021, 09:24:06 pm »
working on more details, 20mm mounting pad, vent cowls, DF loop mounting,
Nordlys
« Reply #171 on: October 22, 2021, 07:40:33 am »
I keep looking at how good that brass windscreen frame is. Are you going to paint or leave as is?
The other additions and parts are a pleasure to see.
N
tghsmith
« Reply #172 on: October 22, 2021, 11:27:52 am »
it will get painted,, still have to make and fit the "glass" and clearviews+ supports..
Nordlys
« Reply #173 on: December 03, 2021, 05:45:18 pm »
It's OK tgh, no rush. Just need to see your pictures of the finished Raf launch, when you get time.
It's been such a detailed build we've been watching with much interest.
Thanks,
Nord.
tghsmith
« Reply #174 on: December 03, 2021, 06:13:33 pm »
work and other things have been crazy busy,, spent two days free time just getting the shop organized,, started back doing some work on my 1/6th scale 1890's live steam navy steam launch.. I'm going to try 2days worktime per model per week!!
Pages: 1 2 3 4 5 6 [7] 8 9 10   Go Up
Page created in 0.158 seconds with 19 queries.
