Pages: 1 2 3 4 5 6 7 8 [9] 10   Go Down
Author Topic: RAF HSL whaleback in 1/16th  (Read 61176 times)
Re: RAF HSL whaleback in 1/16th
« Reply #200 on: April 04, 2022, 01:25:36 am »
Yes excellent....the vertical of the 4 on the Stern on axis with the axis of the vessel  :-))  .......... Derek
tghsmith
« Reply #201 on: April 08, 2022, 12:17:52 am »
some rework and small details, needed to make the cabin top hatch hinges stronger so an aluminum unit was milled, this is a working hatch that gives access to the main switches.. the cabin sides have several drain tubes with small directional covers,, formed the covers from some brass shim stock.. 1/16th scale is an evil master.....
tghsmith
« Reply #202 on: April 09, 2022, 04:43:55 pm »
working on more cabin details, found a error in the plans on the mast heigth.. correction was to make new mast 1.5" taller (correct mast main section is 17ft tall, 1/16th at 12.75") the sickbay hatch needs to detailed and a few small bits on the cabin.. got a good start on the yardarm..
tghsmith
« Reply #203 on: April 11, 2022, 11:51:02 pm »
detailed the sickbay hatch and a few other small bits..
tghsmith
« Reply #204 on: April 14, 2022, 01:12:13 am »
while working on the mast and yardarm the flags arrived, I'm more than pleased with them!!!
RST
« Reply #205 on: April 14, 2022, 01:16:30 am »
Superb work!  But that coin you show in the various pics, how big is that please - we don't know for scale?
tghsmith
« Reply #206 on: April 14, 2022, 01:27:34 am »
US penny  3/4 of an inch across..
Tworrs
« Reply #207 on: April 18, 2022, 03:08:24 am »
A great build, and so much amazing detail, thank you
Garry
tghsmith
« Reply #208 on: April 19, 2022, 11:21:18 pm »
more mast details, a few spot need a little clean-up after the primer has cured..
tghsmith
« Reply #209 on: April 22, 2022, 11:15:30 pm »
a little small turning and some small soldering,, the bow lifeline stanchions are ready..
tghsmith
« Reply #210 on: April 25, 2022, 11:26:36 pm »
a screen grab from "for those in peril" has sent me working on the correct deck markings,, larger taller numbers with the checkerboard moved father forward.. I drew out the checkerboard and am working on the new font for the numbers.. glad I got this info as the "incorrect" deck paint work was about to start..
tghsmith
« Reply #211 on: April 29, 2022, 12:49:16 am »
did the lay out for the deck numbers and started planning the gun stanchions
tghsmith
« Reply #212 on: April 30, 2022, 12:13:27 am »
lots of hours taping and masking and a few minutes spraying and airbrushing!!!
Tworrs
« Reply #213 on: April 30, 2022, 10:57:21 am »
And a fine job you did of it too, Sir.
tghsmith
« Reply #214 on: May 03, 2022, 12:00:08 am »
thank you all, gave the deck its color coat, done with all taping and masking, can start mounting the deck fittings..
tghsmith
« Reply #215 on: May 04, 2022, 12:09:39 am »
color coats on more parts, set the deadlights in thin silicone , once cured they were filled drop by drop with tinted resin to the proper level..
tghsmith
« Reply #216 on: May 04, 2022, 11:54:33 pm »
the "glazing" of the deadlights worked well, did some silver solder work to get a start on the stanchion gun mounts
tghsmith
« Reply #217 on: May 05, 2022, 11:41:57 pm »
a little more work on the stanchions and shields..
RST
« Reply #218 on: May 06, 2022, 12:11:59 am »
Hi, thanks and sorry...
...I think thats about a 5p coin over here.  Pretty small!
I think I'm ahead of here watching you on RCgroups.  It's a great build to watch.
Thanks and regards,
tghsmith
« Reply #219 on: May 07, 2022, 12:00:02 am »
a little clean-up and primer has the mounts looking better
tghsmith
« Reply #220 on: May 10, 2022, 12:45:58 am »
started the conversion of US pt boat gunners to RAF gunners, it's coming along, took away his coffee and offered him some tea, that didn't go well, told him he would get some rum later, that helped..
tghsmith
« Reply #221 on: May 12, 2022, 10:48:21 pm »
second gunner put together, they got their boat books and socks, paint after a little more work, used a file to give the socks a woven look..
« Reply #222 on: May 12, 2022, 11:00:32 pm »
That's a good idea and one I've never seen before so thank you for sharing.
tghsmith
« Reply #223 on: May 15, 2022, 07:09:39 pm »
gunners look a little better with some base colors in place, have decided to detail the engine room, instead of the motorman sitting on a plank he'll get the proper chair on top of a sealion engine, speaker will get moved forward so the other two engines can be added..
tghsmith
« Reply #224 on: July 04, 2022, 04:18:11 pm »
I was away for about a month, clearing out my parents house and buildings (not a vacation!!) back to work on the engines, block and reduction gear were vacuum formed, masters and mold made for other parts, the casting resin I'm using drills and carves easily which will help keep the weight down, should have all the parts cast in the next few days..
Pages: 1 2 3 4 5 6 7 8 [9] 10   Go Up
Page created in 0.203 seconds with 18 queries.
