Author Topic: KYTE Motors - MFA 385  (Read 5423 times)
rnli12
« on: October 01, 2016, 01:49:00 pm »
Does anyone know whether the Deans KYTE Motors could be interchanged with the MFA 385?
Sorry MODS can you move this to brushed section!
Cheers,
chas
Re: KYTE Motors - MFA 385
« Reply #1 on: October 01, 2016, 07:49:54 pm »
Hi, there are several different Kyte motors, which one are you thinking of? Alternately, what model and prop is it for?
Chas
rnli12
« Reply #2 on: October 01, 2016, 08:01:01 pm »
Its for the Trumpeter USS Missouri in 1/200th scale.
chas
« Reply #3 on: October 01, 2016, 11:10:31 pm »
We haven't a Missouri in our club so I don't have direct experience of the model. I use 2 385s in a smaller cruiser, but, good as they are I wouldn't choose them for a 54 inch model.
 I'm not sure how many motors you are going to choose, if it's 2 I would consider 2 550 motors. Low ish reving and torquey. They also have a wide voltage range so getting the right speed should be easy. Don't confuse them with 540s, they are very different.
 You won't need a lot of power, but you will need torque, to get it moving well. The props will be important.
 I seem to remember Glyn Guest using a 550 in his Sheffield to very good effect, that was similar in size.
 Hope that helps,
 Chas.
Stan
« Reply #4 on: October 01, 2016, 11:46:49 pm »
Fitting 550 motors may be a problem. The shafts will be at a very shallow angle which may give problems with alignment.When I had a 1/200 Yamato around 54 inch it was powered by 4 motors about the same size of 385 and the model sailed very well with a good turn of speed.I have the Missouri kit and it will be powered using 385 motors driving 4 shafts.These are my thoughts on this post only.I have no wish to Influence your final choice of motors
Stan. :-)) :-))
chas
« Reply #5 on: October 02, 2016, 12:05:24 am »
The problem with " about the same size" is that it covers too many variables. 380  and 385 motors are the same size, and as different as you can get. If alignment is a problem, I would choose a belt drive.
Chas
Stan
« Reply #6 on: October 02, 2016, 08:55:27 pm »
Hi RNLI having checked the mayhem site numerous conversations have been done on the 1.200 scale  Yamato. All have been fitted with 385 motors  hope this helps. The Missouri is about the same size fitted with some decent props from a well known supplier I think you will have no problems. Again I have no wish to influence the choice of motor or props  to fit to this model. See Mayhem Oct 28 2012
Stan
unbuiltnautilus
« Reply #7 on: October 04, 2016, 01:32:06 pm »
I have yet to come across a bad 385 motor. As long as you request a '5 Pole' type of motor, you will end up with a medium power motor, which, x4 should be fine for a 1/200 scale warship of this size.
rnli12
Re: USS Missouri Trumpter 1/200th
« Reply #8 on: December 04, 2016, 03:37:17 pm »
Just moving along with my Missouri what shafts to use, im tempted with 2mm shafts as 4mm seems a bit overscale, any thoughts? and propeller choices?
Cheers,
Stan
« Reply #9 on: December 04, 2016, 08:26:24 pm »
I have this for a future build and I will be using 2mm shafts  I think the max length you can use  is about 12in.  My props and shafts came from Model Boat Bits  2 4 bladed props 2 5 bladed props. I have used 2mm shafts on my Elco conversation with no problems. Some extra support may be needed for external shafts inside the hull hope this helps. See warships and military elco 80 ft conversation.
Stan. :-)) :-)) :-)) :-)) :-)) :-)) :-))
rnli12
« Reply #10 on: December 05, 2016, 05:53:17 am »
Thanks Stan, I recall you mentioning 2mm shafts when we spoke last.
Much appreciated as always,
Page created in 0.012 seconds with 17 queries.
