Author Topic: robbe duo memory switch  (Read 3894 times)
foreender
« on: November 12, 2016, 06:39:44 am »
my memory switch does not power out when the led lights up,can this be repaired,or is it the recycle bin >>:-(
g6swj
  • Short Wave Jammer! -.-
Re: robbe duo memory switch
« Reply #1 on: November 12, 2016, 08:32:30 am »
Is this happening on both switches?
Can you hear the relays clicking?
Jonathan
foreender
« Reply #2 on: November 13, 2016, 08:26:36 am »
yes, the relays are working,but no power out.
inertia
« Reply #3 on: November 13, 2016, 09:18:33 am »
Dumb question here. Have you got power connected into the relays?
DM
g6swj
« Reply #4 on: November 13, 2016, 03:26:50 pm »
Relays clicking is a good sign - that suggests that the Robbe Duo board is working in relation to being powered and receiving the signal from the RX.
I am sure you know that effectively each "switch" is made up of 2 parts (seperate circuits) - the middle man seperating the 2 electrically but also joining the 2 physiically is the relay.
Can you desribe what you have on the relay side - cable connected from and to, power supplied from , switching lights, sound, pump etc and we maybe able to point to in the right direction as to a fix...
May be a pic would help...
Jonathan
foreender
« Reply #5 on: November 13, 2016, 04:29:20 pm »
Oops, never thought  to check the cartridge fuse, it looked ok, forgot its on a separate circuit.Thanks chaps, red face again Aye, Bill.
g6swj
« Reply #6 on: November 13, 2016, 04:51:13 pm »
Bill,
Pleased you solved the problem
We have all been there at one time or another!
I once went to replace the power supply in a computer - as I came to remove the "dead" item someone had added an "on/off " switch on the back of the case that I swear was never there - a simple click and the "dead" power supply amazingly came back to life.... I am amazed that I did not spot it, how it got switched off in the first place I will never know...
To this day I have the new replacement power supply, never fitted, smiling at me from it's place on a shelf in my den...
Jonathan
Page created in 0.566 seconds with 18 queries.
