Author Topic: Measuring Bulkheads etc?  (Read 5983 times)
tizdaz
  • Boom!
    • My RC TID Build
« on: November 18, 2016, 04:52:17 am »
Hi guys :)
My Hull is GRP & i want to re-inforce it using wooden bulkheads, whats the easiest/best method to get the correct size/shape so they fit snug?
Same for the deck to, should i use some cardboard as a template? and is the best method for deck to lay down a piece of cardboard large enough then get the hull and place it face down onto the cardboard & then draw a line all the way around on the cardboard?
Should i make templates using cardboard or ?
Any info or tips for muchos appreciated as always :)
Thanks guys/gals :)
My large-scale TID Build Website:
http://www.tizdaz.co.uk
Facebook:
colin-d
    • my hobby
Re: Measuring Bulkheads etc?
« Reply #1 on: November 18, 2016, 05:36:11 am »
there are some handy gadgets around that will "measure profile contours" if you put that in Google you will see what I mean...
there are other ways, for example if you have a strip of roofing lead, you can force it into the Hull and it will follow the contours, making templates out of cardboard or thick paper is always a good idea .. !!
tizdaz
  • Boom!
    • My RC TID Build
« Reply #2 on: November 18, 2016, 06:05:28 am »
cool thanks :)
those profile contours are what im looking for, just need to try find one large enough now that aint too expensive! :D
Facebook:
« Reply #3 on: November 18, 2016, 07:31:33 am »
Doing half profiles would mean you could use a smaller gauge for the bulkheads.
RAAArtyGunner
« Reply #4 on: November 18, 2016, 07:45:13 am »
Doing half profiles would mean you could use a smaller guage for the bulkheads.
JimG
« Reply #5 on: November 18, 2016, 10:16:30 am »
You could use a flexible curve such as this
https://www.amazon.co.uk/Helix-60cm-Flexible-Curves-U46010/dp/B002HRAB6C
It's a decent length and will hold the shape to get the contour.
Jim
Dundee Model Boat club
Jerry C
« Reply #6 on: November 18, 2016, 10:42:57 am »
See Jerry's steam launch wear, on page 3 of steam. Reply number 107 for the correct method of marking out for a bulkhead.
Good luck
Jerry.
« Reply #7 on: November 18, 2016, 11:29:33 am »
Will you need bulkheads?
Andy's hulls are fairly rigid
heavyweight layup.
By the time you have fitted
a beamshelf and deck beams
you should have a very rigid
set up.
tizdaz
  • Boom!
    • My RC TID Build
« Reply #8 on: November 18, 2016, 06:47:05 pm »
hi guys :)
I wasn't too sure whether I needed to fit bulkheads or not, but I've decided on fitting 4 as they will also be used to place a base onto for the electrics/motor/batteries etc :)
Facebook:
Plastic - RIP
  • Inactive
  • Bobbing Along!
« Reply #9 on: November 18, 2016, 09:14:00 pm »
I always fit bulkheads just in case of accidents and water ingress and to stop the water sloshing and causing a capsize and damaging every electronic component on board.
Also, spare volumes can be filled with foam to make it completely unsinkable - easier to retrieve a dead boat still on the surface rather than at the bottom of a muddy lake.
tizdaz
  • Boom!
    • My RC TID Build
« Reply #10 on: November 18, 2016, 11:58:22 pm »
very true :)
Like i say i will be adding probably around 4, not 100% sure how many yet as ive yet to recieve the hull etc :)
Facebook:
Page created in 0.053 seconds with 18 queries.
