Author Topic: MMM Portgarth build  (Read 455934 times)
Butts
  • Secretary, Balne Moor Model Boat Club
    • http://balne-moor-model-boat-club.myfreesites.net/
Re: MMM Portgarth build
« Reply #1100 on: February 05, 2019, 07:00:20 pm »
Andy,
Mike Allsop of Scale Flags and Ensigns can supply them.
There are two Svitzer flags, the older one with the propeller and the later one which just has the company name- he does both.
My tugs have the later one.
Taranis
  • Balne Moor MBC
« Reply #1101 on: February 05, 2019, 07:49:36 pm »
Excellent thank you Micheal
I have used him before for lifeboat flags so should have Known  :embarrassed:
ANDY
Taranis
  • Balne Moor MBC
« Reply #1102 on: February 06, 2019, 05:38:33 pm »
Here I've used an old decimal half penny to make the platform for a dome shaped navigation device(no idea what it is specifically) I've ordered some dome shaped sticky backed rubber feet and one will be used sprayed white to top it off.
Some more aerials to add yet and two lights on the ladder cage.
Dome is top right here
ANDY
Taranis
  • Balne Moor MBC
« Reply #1103 on: February 06, 2019, 10:30:19 pm »
Mast aerials fitted and removable.
Best picture available of Portgarth mast
ANDY
steve mahoney
« Reply #1104 on: February 07, 2019, 12:29:04 am »
You must be pleased with that mast! It looks great but what a nightmare to solder.
Taranis
  • Balne Moor MBC
« Reply #1105 on: February 07, 2019, 12:34:26 am »
Thank you yes I’m pleased
Actually gave myself a big break by forgoing any lighting
Despite being an electrician I hate fiddly little wires and I don’t think it’s worth the effort as she's sweet enough in daylight.
ANDY
Taranis
  • Balne Moor MBC
« Reply #1106 on: February 07, 2019, 10:46:11 am »
This morning I've considered how to attach the nav lights to the ladder cage.
This is how I've done it
Then soldered and bent so it grips the light base which again will be soldered
ANDY
Taranis
  • Balne Moor MBC
« Reply #1107 on: February 07, 2019, 11:56:08 am »
Not much more now before painting. Great to have consecutive days free at it
ANDY
SailorGreg
« Reply #1108 on: February 07, 2019, 01:46:50 pm »
The little dome is probably a GPS antenna. Looks the right size and position, although if someone else knows different I will bow to superior knowledge.
Greg
Taranis
  • Balne Moor MBC
« Reply #1109 on: February 07, 2019, 01:49:41 pm »
Cheers Greg I figured satellite dome so similar idea
I like GPS  :-))  better
ANDY
« Reply #1110 on: February 07, 2019, 02:02:35 pm »
Seeing the S in GPS is satellite you are both correct.
Taranis
  • Balne Moor MBC
« Reply #1111 on: February 07, 2019, 02:10:27 pm »
Kind of you Ned but to be fair I was thinking more the type for finding the porn channel  %%   {-)
ANDY
Tafelspitz
  • Model Boat Bedlam
« Reply #1112 on: February 07, 2019, 02:15:37 pm »
Actually, S is for System - as in Global Positioning System - but since it's satellite based, I'll let it count  :}
Awesome detail work on that mast and ladder cage. Blows me away!
We live in a society exquisitely dependent on science and technology, in which hardly anyone knows anything about science and technology.  Carl Sagan
Taranis
  • Balne Moor MBC
« Reply #1113 on: February 07, 2019, 02:17:08 pm »
Thank you and the admiration is very much mutual Love yours too  :-))
ANDY
Taranis
  • Balne Moor MBC
« Reply #1114 on: February 07, 2019, 02:19:46 pm »
Fuller image
ANDY
Taranis
  • Balne Moor MBC
« Reply #1115 on: February 07, 2019, 02:22:24 pm »
This final aerial was a problem but I’ve overcome by drilling two small holes in the stanchion and I think it is a good enough fit not to glue it.
There are other small aerials but I think I done enough with four
ANDY
Mark T
« Reply #1116 on: February 07, 2019, 05:01:34 pm »
Nice tidy job Andy  :-))
Taranis
  • Balne Moor MBC
« Reply #1117 on: February 07, 2019, 06:42:56 pm »
Thanks Mark  :-)
Not the right blue but a good base coat.
Assembled for effect. Renault Royal blue on Saturday
ANDY
Taranis
  • Balne Moor MBC
« Reply #1118 on: February 07, 2019, 07:19:10 pm »
I am amazed by the superb quality of your workmanship, Taranis!
I have been looking for the right size of the towing hawse, myself.
compared to the size of your crew member, yours looks rather thick. Is it based on research?
In my model 1/33, a five mm string equals more than 16 cm real life. I thought that would be about right. What do you think?
Do you have an idea, where in real life they use steel rope and where soft natural or synthetic rope material?
Also, I have thought that I could simulate a steel rope by simply painting an appropriate string. I wonder, if it works. It would only be for display, of course. I think ropes for tieing, towing business must be more practical (I found a very nice hemp string lately).
Hande
Smaller rope fitted with a nice weave  :-))
ANDY
Taranis
  • Balne Moor MBC
« Reply #1119 on: February 07, 2019, 07:56:20 pm »
All those familiar with building a Portgarth will be aware of the plan and templates being wrong leading to a completely inadequate companionway landing. Now the mast is under control I am focusing on this issue and a sympathetic solution.
The problem
My first idea comprising of paxolin and railing.
The general idea. I cant really overcook this or it will cause issues with removing the superstructure.
I can use perhaps a Fire box fitted to the paxolin with long brass pins to plug it straight into the deck riser.
This initial assembly will be fully finished in Rover Arum white to match
ANDY
Taranis
  • Balne Moor MBC
« Reply #1120 on: February 07, 2019, 09:50:08 pm »
I think that works for me and additional detail will enhance them. Best of a bad job sorted.
ANDY
Taranis
  • Balne Moor MBC
« Reply #1121 on: February 08, 2019, 02:02:10 pm »
I’ve now ordered the flags with lines attached
Red ensign and both Svitzer flags
Cheap as chips excellent service
Thank you Mike & Mike  :-))
Thank you for your enquiry,  all these flags are available with lines I use white cord of 20inch length if you need longer please let me know.  The flag sizes are Red ensign 50x25mm . The house flags are both 36x24mm.  Total costs for flags, P&P, and lines is £11.00.
ANDY
Taranis
  • Balne Moor MBC
« Reply #1122 on: February 09, 2019, 03:05:37 pm »
Mast is now painted in renault royal blue despite the weather.
Now I could do with advice here on the colour of the lights. The port side red/white/red are obvious but the forward facing centre 3  / mast head and rear facing pair are not so easy
Meanwhile I was drawn to finishing off with a fifth aerial
Final assembly in progress
The three lights fitted are set in stone but the rest?
ANDY
Taranis
  • Balne Moor MBC
« Reply #1123 on: February 09, 2019, 03:56:59 pm »
A bigger lens used here for less fish eye. Amazing how clean my glass is  {-)
ANDY
Mark T
« Reply #1124 on: February 09, 2019, 04:20:02 pm »
That really is a lovely build you must be really pleased with your results.  Is it finished now or are there a few little jobs left?
Page created in 0.609 seconds with 18 queries.
