Author Topic: Receiver--voltage  (Read 6979 times)
gyjoe
Receiver--voltage
« on: April 24, 2017, 01:54:57 pm »
Hi All,
        Need some help if possible,I do not understand voltage to my receiver,6volts to 8.4 volts,anything more will damage the receiver
I want to use 12volt batteries,how can I do this without causing any damage,you will have gathered by now I'm new to this
        joe
Re: Receiver--voltage
« Reply #1 on: April 24, 2017, 02:21:42 pm »
If your ESC has a BEC (Battery Eliminator Circuit) that will provide the correct voltage to the RX. Otherwise use a separate battery for the RX.
gyjoe
« Reply #2 on: April 24, 2017, 02:41:16 pm »
Cheers Mate,
                      Thanks for your help
                                                joe
Klunk
« Reply #3 on: April 24, 2017, 02:45:18 pm »
what make is the esc???
full time penguin
« Reply #4 on: April 24, 2017, 02:54:23 pm »
Yes thankyou for discussing this chaps  8) I now know exactly what a BEC is and can wire up one of my models with confidence.
gyjoe
« Reply #5 on: April 24, 2017, 03:02:49 pm »
  Carson Reflex Stick2 6 channel
gyjoe
« Reply #6 on: April 24, 2017, 03:18:08 pm »
Ihave a p93 multicontoler
« Reply #7 on: April 24, 2017, 04:40:34 pm »
Right then i presume from your post you have one of these
http://www.action-electronics.co.uk/pdfs/P93.pdf
if so it does not have a bec and will need a seperate receiever pack........
are you using an ACTion power board or not.....if not the contact Component Shop and ask them fior  a 5v bec power supply....this is simple to wire up....just connect poss to batt and negative to batt and the receiever is connected to it via the 3 cable plug.....simple as that as there unit will then reduce your batt voltage to 5v to supply your receiver
« Reply #8 on: April 24, 2017, 04:47:28 pm »
P19 BEC 1A BATTERY ELIMINATOR - £ 9.00 Incl VAT
http://www.action-electronics.co.uk/pat.html
« Reply #9 on: April 24, 2017, 04:50:43 pm »
none in Stock i do believe Martin but they have others i know that for a fact
« Reply #10 on: April 24, 2017, 05:19:53 pm »
gyjoe
« Reply #12 on: April 25, 2017, 02:32:13 pm »
Dave,
        What you presume is correct Action P93 Multicontroler  I will be using an Action P92 power distribution board
                                        regards
                                                  joe
« Reply #13 on: April 25, 2017, 04:19:39 pm »
Joe simply connect the cable with 3 wres and the small plug into your reciever red/brown/black and away you go NO need for a separate batt pack or anything...The P102 alreay has this facility
« Reply #14 on: April 25, 2017, 04:30:10 pm »
Dave, Joe is not using a 102, but a 92.
No facility for bec on the 92.
Joe, you will still need a ubec off your
12V supply or a 6v nihm receiver pack
« Reply #15 on: April 25, 2017, 04:56:42 pm »
Ned you are incorrect m8 there is a bec on the 92
http://www.componentshop.co.uk/p92-power-distribution-board.html
[/size]The P92 Power Distribution Board provides a neat solution to "Rat's Nest" wiring when multiple units are installed in a R/C model boat. Two separately fused groups @ 6V - 12V input voltage PLUS a regulated 5v 'BEC' for Rx supply. Includes TWO FULL sets of fuses and a universal servo/BEC lead . Board size is 64mm x 70mm; unit is uncased. Screwdriver connection. 6v BEC version also available[/color]
Yes I did a typo error stating P102 ....Jim you DO NOT need a seperate batt pack.....if you dont believe what is said on here phone Component shop who will confirm what I have said
« Reply #16 on: April 25, 2017, 05:11:24 pm »
I hang my head in shame Dave.
You are correct Sir.
I must have missed the bec connection
on my printout of the schematic.
gyjoe
« Reply #17 on: April 26, 2017, 01:08:23 pm »
Thanks Lads
                      For all your help,without it I would be nowhere
        Joe
Geoff
« Reply #18 on: May 11, 2017, 01:47:00 pm »
For what its worth, I would always use a separate battery for the receiver. Too many chances of the main battery running down and then shutting the receiver down. I've never been struck on the BEC concept - good in theory and I know lots of people use them but also lots of people loose control some times and it invariably a battery voltage issue.
Geoff
« Reply #19 on: May 11, 2017, 07:37:22 pm »
On the other hand, if the main battery runs down that far, there is nothing to control.  With more than one battery there is a good chance that the least noticed one, probably the RX one, will not be charged.  Hopefully it will just leave the boat drifting, but it could leave an uncontrolled boat doing its own thing maybe flat out.  Or, depending on wiring and ESC, reverse only.
Anyway, a separate BEC, if required, takes up less space and weighs less than almost any RX battery and will always give the proper regulated voltage as long as the main battery has enough go to drive the rest of the boat.
Of course, for a big collection of extras like lights, sounds, working goodies, a separate battery for them makes lots of sense.
« Reply #20 on: May 11, 2017, 10:01:22 pm »
Most people I have seen sailing rarely run their model long enough to worry the battery anyway (Perhaps it is a Yeovil thing!) so unless you are doing a seriouss amout of sailing, or you use the same battery for more than one model in a session, then just be careful and keep your batteries charged in the manner they work best in.
T33cno
« Reply #21 on: May 12, 2017, 08:54:38 am »
Component shop will be at Doncaster show this weekend as of today. I suspect they have been saving stock for there to avoid embarrassment and not updating online stock status for now.
I agree there is no point having power to the receiver if everything else won't work  {-)  A BEC is the way as many have said ;)
I have noticed with mine that the main motors do start to noticeably under perform well in advance of the receiver which is as I'd expect as its the reduction in battery voltage that slows them but as the receiver uses a much lower voltage it is unlikely to die
« Reply #22 on: May 12, 2017, 01:22:29 pm »
What show is on at Doncaster this weekend?
( CADMA Northern Model Boat Show 2017 - Saturday 3rd and Sunday 4th June 2017 )
(  Doncaster College for the Deaf, Leger Way, Doncaster, DN2 6AY  )
T33cno
« Reply #23 on: May 12, 2017, 01:23:42 pm »
National model engineering exhibition Martin
