For ballasting, if you didn't want to go the route of pumping water in and out, I would choose the lead block method.
Cut Code 4 lead flashing sheet into 3 inch squares (a hobby guillotine is ideal for this), stack them into a block sufficient to weigh 1 or 2 kilos each, compress them in a vice between two sheets of ply to flatten them completely and then bind them together with electrical tape.
These can then be lifted in and out of the model at the pondside easily. You could even leave a few blocks in the hull permanently, but not all of them.
Size for size, lead is smaller than bags of sand and gravel for the same weight due to the density of the material - think of all that air surrounding the aggregate in the bag that you are dropping into your hull. The lead will take up far less space - both in the hull and in your car to the pond!!!
C
PS - this is what I do with my 8' long model of the SD14 cargo vessel - and she is primarily made of liteply and cardboard.
