Pages: 1 2 3 4 5 6 [7] 8   Go Down
Author Topic: 1/200 scale Yamato  (Read 64404 times)
Stan
Re: 1/200 scale Yamato
« Reply #150 on: September 07, 2019, 03:47:23 pm »
Hi CJK no pictures straight from the camera on to the p/c. Then right click on picture then edit then resize  then save has.  All these steps are done using the paint program.
Stan. :-)) :-)) :-)) :-)) :-))
CJK
  • Growing old is mandatory - growing up is optional
« Reply #151 on: September 07, 2019, 05:06:48 pm »
I knew you wouldnt be Stan  :} , Photoshop is used by cheats to hide mistakes - you just don't make any by the looks of it. One day I might be as good.  %)
Stan
« Reply #152 on: September 07, 2019, 08:50:40 pm »
Hi Guys just a few pictures showing the secondary turrets these  are still under construction and not painted. I have made them removable by using magnets.
Stan.
« Reply #153 on: September 07, 2019, 09:00:30 pm »
I like that idea Stan - magnets and locating pins / holes - belt and braces, so to speak.  :-))
Stan
« Reply #154 on: September 07, 2019, 09:06:41 pm »
Hi Capt Podge the magnets along with the locating holes works a treat.
Stan. :-)) :-)) :-)) :-)) :-)) :-)) :-))
Stan
« Reply #155 on: September 09, 2019, 07:56:11 pm »
HI all hopefully back on the build tomorrow.
Stan.
Stan
« Reply #156 on: September 10, 2019, 06:31:16 pm »
Now back working on this build  painting most of the day pictures to follow.
Stan
« Reply #157 on: September 16, 2019, 09:08:41 pm »
Just a little work done over the last few days.
dlancast
« Reply #158 on: September 16, 2019, 11:00:09 pm »
Very nice and clean sir.
Stan
« Reply #159 on: October 01, 2019, 05:50:16 pm »
I have just  got back from my hols hope to restart work later this week.
Stan.
CJK
« Reply #160 on: October 01, 2019, 07:51:51 pm »
Hope you had a good holiday Stan. Looking forward to your new tricks with Yamato.  :-))
raflaunches
  • The Penguins are coming!!!
« Reply #161 on: October 02, 2019, 08:51:40 pm »
Fantastic build so far Stan.  :-))
Nick B
Illegitimi non carborundum!
« Reply #162 on: October 02, 2019, 09:27:58 pm »
Looking forward to seeing more on this one Stan and by the way, the chequer plate looks fantastic  O0
Stan
« Reply #163 on: October 03, 2019, 07:54:06 pm »
Hi All back on this build once again pictures to follow.
Stan
« Reply #164 on: October 05, 2019, 03:38:06 pm »
Hi just a little done today. Magnets fitted to hold down main superstructure also fittings glued in place  to keep anchor chains under tension.
« Reply #165 on: October 05, 2019, 03:46:52 pm »
Hi Stan,
A question if I may - are the anchor chain tension holders located somewhere under the focsle deck?
Just curious...
Stan
« Reply #166 on: October 05, 2019, 06:22:20 pm »
Hi Ray no the chains are quite long allowing the tension fittings to be fitted in the centre section. Plus easy to get too
Stan.
« Reply #167 on: October 05, 2019, 06:49:13 pm »
Ahh, yes, that makes perfect sense.
Cheers Stan  :-))
T888
« Reply #168 on: October 06, 2019, 02:12:49 am »
Hi Stan, do like the magnet and pin idea.
Question, how are you going to seal/ water proof the wood decks
Regards David
Stan
« Reply #169 on: October 06, 2019, 07:58:07 am »
Hi T888 I have already tried thinned Humbrol varnish on a wood deck test piece with no problems. The edges will be sealed with thin superglue hope this answers your questions.
Stan
T888
« Reply #170 on: October 06, 2019, 09:25:40 am »
Regards David
Stan
« Reply #171 on: October 06, 2019, 08:41:04 pm »
HI Guys once again only a little done today. Rear gun turret will be held place using magnets  this will allow access to the radio on /of switch. Pictures show magnets installed and gun turret glued to its mount Other pictures are just general shots sorry about the mast picture. Hopefully it will be at Blackpool.
Stan
« Reply #172 on: October 18, 2019, 07:02:45 am »
Hi all not much done this week getting ready for Blackpool.
Stan. :((
Stan
« Reply #173 on: October 22, 2019, 05:42:31 pm »
Now Blackpool show is finished I hope to concentrate more on the Whitehall having a break from1/200 scale.
Stan. :-)) :-)) :-)) :-)) :-)) not for long
Stan
« Reply #174 on: November 02, 2019, 04:45:56 pm »
Hope to be back on this next week.
Stan.
Pages: 1 2 3 4 5 6 [7] 8   Go Up
