Author Topic: Building the FV "Mady Jeanne"  (Read 201485 times)
missyd
Re: Building the FV "Mady Jeanne"
« Reply #325 on: April 07, 2018, 06:49:26 am »
Thank you very much for the compliments!!!!! :-)) :-)) :-))
I try to do my best to keep you entertained all the time ...  ok2
I added the planks on the other side of the bow .... not many left to do there ....
At the stern there is a lot of work waiting for me .... and I have to start thinking about the motor size, reduction gear, water pumps and the piping for them ....
I always fill the spaces at the bow with glue ....
Danielle
GAZOU
« Reply #326 on: April 07, 2018, 08:11:09 am »
Hello
On the real hull the lined are fixed to more spaced out couples, example: row1 on couple 4, row 2 on couple7, row 3 on couple 1
best regard
« Reply #327 on: April 07, 2018, 09:32:57 am »
It really is a nice piece of woodwork, and it is looking really good, cannot wait for the next pictures.  :-)
missyd
« Reply #328 on: April 07, 2018, 10:17:32 am »
Hello
best regard
Yes I know that .... on a model it just doesn't matter as the wood won't be visible at the end. I may build another model after this one and all mistakes made sofar will be corrected and the model will be even better! ok2
Thanks alot SteamboatPhil. I'll try to do my best to keep you and all followers happy. I have to think about how the wheelhouse and netwinches will be placed on deck....
Danielle
« Reply #329 on: April 07, 2018, 03:10:48 pm »
You're keeping us very happy Danielle  :} Just keep doing your thing Missy 25000 views  :-))
missyd
« Reply #330 on: April 12, 2018, 07:00:37 pm »
The planks at the stern are ready to be sanded down .... wait! I have to nail in all nails into the planks first.... {:-{
And I gave the keel/propshaft aera some nice shape too ....
Danielle
jarvo
  • Etherow model boat club
« Reply #331 on: April 12, 2018, 09:24:25 pm »
Great to see the progress, looking superb
Mark
Tugs are for pulling
steve mahoney
« Reply #332 on: April 13, 2018, 03:59:30 am »
"I may build another model after this one and all mistakes made so far will be corrected and the model will be even better!"
... and so begins a never ending list of projects.
GAZOU
« Reply #333 on: April 13, 2018, 04:22:18 pm »
Hello
That go to be made nails?
Big Ada
« Reply #334 on: April 13, 2018, 05:48:41 pm »
There are some people on here that would like to know how many nails you have used, No Names  O0 O0 O0
Len.
steve mahoney
« Reply #335 on: April 13, 2018, 08:10:31 pm »
They would be rivet counters.
missyd
« Reply #336 on: April 13, 2018, 08:12:26 pm »
There are over 240g of 15x1 nails in this hull ....  ok2
Don't know how many this are ... they are sold in packs of 30g ....
Danielle
« Reply #337 on: April 14, 2018, 03:09:59 am »
Easy to answer  %).....and the answer is 2,246 zinc plated panel pins of 15 x 1 sizing  :P
Calculated from 4680 pins per 500gm....[manufacturers listing]
So 936 pins per 100gm x 2.4 = 2246 {-)
missyd
« Reply #338 on: April 14, 2018, 04:46:09 am »
Now thats a big number!!!! 2246 nails .... some of them fell on the floor and some of them where replaced because I bend them ....  ok2
I like to nail the planks onto the frames. I saves me from using zig millions clamps and waiting a long time till I can glue the next plank. With my method I can fix some 4-5 planks in 2 hours.
BTW I had to switch from 13x5 to 10x5 planks. Bending was getting very difficult.
Danielle
GAZOU
« Reply #339 on: April 14, 2018, 06:14:12 am »
I wanted to say: how go to sand you the wood with the nails which overtake
missyd
« Reply #340 on: April 14, 2018, 05:55:30 pm »
No Problem! All nailheads will be hammered in 1-1.5mm further into the wood before sanding the planks.
The picture shows how this will look. The "holes" will then be filled with putty ...
Danielle
RAAArtyGunner
« Reply #341 on: April 16, 2018, 12:01:01 am »
Instead of Putty, you could use a filler of creamy texture,  spread it over all the planks, filling the nail holes and gaps in one operation and then sand down to shape.
Some of the 'modern' wood fillers can be thinned to watery/creamy consistency. The catch is if thinned with 'thinners' quick evaporation will occur. So if possible a water based filler is more suitable. Gives more time to work and better for the wood.
Looking good O0 O0 O0 :-)) :-)) :-))
jarvo
« Reply #342 on: April 16, 2018, 07:20:24 am »
I think that sanding dust mixed with PVA is far superior, or even better 2 pack epoxy thinned down mixed with the dust, but more difficult to sand back.
RAAArtyGunner
« Reply #343 on: April 16, 2018, 07:44:12 am »
Don't use that trick if you are applying a polish or timber stain over the wood as the PVA will show through as 'water' type stain, as it seals the grain.
« Reply #344 on: April 16, 2018, 02:12:49 pm »
A very useful bit of info.   :-))
Thanks for that, I didn't know.
Brian60
« Reply #345 on: April 16, 2018, 02:45:26 pm »
If you use the right type of sandpaper then you do not need to bed the nails down. The sandpaper will happily remove the nail heads as you sand.
GAZOU
« Reply #346 on: April 16, 2018, 05:29:13 pm »
Certainly not
RAAArtyGunner
« Reply #347 on: April 16, 2018, 11:51:26 pm »
Brian is no doubt referring to metal removing papers such as wet and dry, emery, etc, used in car body working.
As such it will work using powered sander, provided that the nails are soft steel and not stainless or hardened. If the wood is very soft softwood then yes pitting will occur around the nail.
Another trick, If you don't want to punch the nails then cut the heads off. Will still hold whilst adhesive sets.
Tricks of the trade are just that, tricks to be used in certain circumstances, not general usage such as kerf cutting on another thread.
missyd
« Reply #348 on: April 17, 2018, 04:23:34 am »
Sanding down the nailheads is not possible .... the nailheads have to be in the planks and not on the planks ... its done like that on the original ....  ok2
Danielle
GAZOU
« Reply #349 on: April 17, 2018, 11:22:43 am »
[citation de l'auteur = missyd link = topic = 58665.msg638718 # msg638718 date = 1523935414] Poncer
les têtes de clous n'est pas possible .... les clous doivent être dans les planches et non sur les planches ... c'est fait comme ça sur l'original ....  ok2
[/ quote]
+1
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25   Go Up
Page created in 0.025 seconds with 17 queries.
