Author Topic: run 2 servo's on 1 bec lead  (Read 2479 times)
Glyn Roberts
  • Creativity is contagious, pass it on.
« on: September 28, 2017, 04:28:54 pm »
Is it OK to run 2 servo's from 1 bec lead.   I have two water cannons on fire boat and want to run them in tandem. The servo's will be aiming the cannons.
Regards Glyn
Re: run 2 servo's on 1 bec lead
« Reply #1 on: September 28, 2017, 06:05:09 pm »
Yes it is
« Reply #2 on: September 28, 2017, 09:17:47 pm »
Provided the BEC can handle the load, yes.  Considering what else might be powered from the same source, most BECs will be OK, more modern UBECs can supply a heavier load.  Most servos you can guess at wanting to pull about 0.5 amps each max.  Is it the same BEC supplying the receiver?
jarvo
  • Etherow model boat club
« Reply #3 on: September 28, 2017, 11:21:48 pm »
Its only the same as the aero boys having 2 aileron servos paired, just make sure that nothing is binding adding to the loaded servos
Mark
Tugs are for pulling
Glyn Roberts
« Reply #4 on: September 30, 2017, 04:02:05 pm »
Thanks for response Guys,  I was making sure that there were no hidden pitfalls.
Regards Glyn
Page created in 0.113 seconds with 17 queries.
